1st Gen R53 Cooper S Sway bar end links
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Sleek Motoring, Jan 21, 2015.
  1. Sleek Motoring
    Sleek Motoring Local Shop Owner
    Dec 7, 2014
    249
    143
    Mini repair shop owner
    Colorado Springs, Colorado
    I am doing the R56 GP aluminum trailing arm conversion on my R53. I need to get R56 end links for the rear. I will probably change the fronts as well.
    I have coilovers and H-sport sway bars front and rear.
    I like the Detroit Tuned adjustable end links because they do not use heim joints.
    Detroit Tuned Adjustable End Drop Links MINI Cooper S R53 R56
    What does everyone suggest for end links?
    If I was going to be changing the end links those are the ones I'd buy. Heim joints aren't going to last long on a street driven car. The dirt will grind them up & make quite a racket doing so.
  3. Dave.0
    Those are the ones I have. They are made by PowerGrid and they are strong and last.
    Buy the from Chad at Detroit Tuned. :Thumbsup:
    You have to buy them from dealers. Powergrid, Inc.
  4. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    They are a very nice end link. Very strong and smooth operation. The sealed boot is key. a Heim joint works for a while but gets really lose and sloppy over time due to dirt and water. In stock ready to ship! (the factory is right down the street from me so i can get any size needed for any custom application, and you can already see we sell several sizes because of lifted countryman's and lowered cars. Detroit Tuned Adjustable End Drop Links MINI Cooper S R53 R56
    Chad
    Detroit Tuned
  5. ScottinBend
    Been running Powergrid end links for years with no issues.
  6. Sleek Motoring
    Dec 7, 2014
    249
    143
    Thanks Chad! I shot you a PM!
  7. Sleek Motoring
    Dec 7, 2014
    249
    143
    Got a set on the way from Detroit Tuned...They are not the cheapest things. Gotta pay to play!
  8. bahawton
    bahawton Member
    Feb 18, 2011
    I run Powergrids and like them, too, but one thing to note when switching to R56 trailing arms: The material is thicker so the end of the bolt is a hair too short.
  9. Sleek Motoring
    Dec 7, 2014
    249
    143
    Do the trailing arms need to be shaved a bit?
    Chad @ Detroit Tuned Shipped my set out lightening fast!
    Thanks!
  10. nkfry
    nkfry New Member
    Roseville, MI
    You can either source a slimmer washer, as I know the washers are a bit on the thicker side, or not install them on the lower mounting point.
    In a perfect world, yes the washer should be there, but we've never had an issue with it not being installed in this situation.
    Glad we could be of assistance, let us know if there is anything we can help you with in the future. :cornut:
    Nick
    Detroit Tuned
  11. JackMac
    JackMac Well-Known Member
    Jan 1, 2010
    399
    251
    PA
    Forgive the noob question, since I haven't lowered a car before. Thinking about KW V2 for my wife's Clubman. Is it recommended to go to adjustable end links at the same time? Anything else to consider when changing to an adjustable setup?
  12. TheModFather
    If you are lowering more than an inch, then yes adjustable end links are a good idea. That one inch rule also applies to at least the lower rear control arms so you can correct the alignment. RMW, and Helix have the best rear LCA's on the market, but others can be had for a lower price point if quality isn't everything to you. ;)
  13. JackMac
    Jan 1, 2010
    399
    251
    PA
    Thanks. I live near Helix, so that is where it would be done.
  14. Dave.0
    John I had Marzo install my V2's with the adj end links above along with adj camber plates.
    I don't think Eric sells the Helix Adj plates any longs but he can still get other types that are just as good. It really helps when it comes to dialing in the car when on the alignment rack.:Thumbsup:
    Also after a year I replaced / upgraded the KW springs to stiffer Swift springs for a much better ride. KW spring are Meh....ok for a while.
  15. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,703
    924
    physician
    York, Pa
    I got Webb's rear end links years ago when he was still around.
    Aurora rod ends with teflon lined bearings and an aluminum center.
    Non-sealed, but they're still doing very well after many salty winters.
    Got them more for the strength compared to stock than the adjustability.
    Would probably go with a sealed variety if I had to replace them.
  16. cristo
    Jan 4, 2015
    5,703
    924
    physician
    York, Pa
    #16 cristo, Jan 24, 2015
    I got Randy Webb's end links many years ago, and although
    they're not sealed, they have held up very well through many
    salty winters. They have Aurora rod ends with teflon lined
    bearings, and a hollow aluminum billet center. He's no longer
    around the MINI community, so if I had to replace them, I'd
    probably go with a sealed design like detroit-tuned, or maybe
    get relacement rod ends from Aurora of the same type and size.
    I got them mainly for the strength over oem rather than the
    adjustability since I'm on oem springs.
  17. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    For this r56 trailing arm mod is it necessary to upgrade/replace both upper and lower control arms? I've got hotchkis lowers but stock OEM uppers.
  18. nkfry
    nkfry New Member
    Roseville, MI
    No need to replace control arms, but you will need to change over to R56 style shocks, they use a different lower mount.
