Suspension Brakes 1st Gen Swift spring question
Discussion in 'Tuning and Performance' started by mrntd, May 2, 2016.
  1. mrntd
    I have swift springs on my R53, just the springs with stock struts (45k mi), not the coil overs. They deliver a much better ride than the stock ones did. In sweepers they work well. But in transitional turns they make the car feel like it's leaning back and forth a lot. I do have a 19mm rear sway bar.
    Do others that have swift springs see the same thing? If not are you still on stock struts?
    Thanks
  2. BlimeyCabrio
    My car was quite flat, on Swift springs with Bilstein B8's. I never ran the stock struts with lowering springs.
    How many miles do you have on your struts? I would expect 11 year old struts to be about shot... Lots of motion in transitional corners could just be the struts not damping at all...
  3. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I agree with BlimeyCabrio. I was using JCW Springs with stock JCW shocks (19mm bar and front camber plates) and started noticing a lot of unbalance during Auto-Xs. I have 96,000 miles on the original JCW springs/shocks. One of my front shocks is dead, does not compress or rebound smoothly when just compressed manually on a workbench. I know that, manual compression, is not a perfect test but it did show that the shock was not well. The shock had no signs of leaking just no longer worked well.
  4. Firebro17
    I'll chime in if its ok. I run the TSW V2 springs with the OEM Cooper S dampeners. I love the ride and it handles nicely when it sees a track (very seldom). Someday it will see new aftermarket shocks and struts, just because... The goal was to have a lowered car that I could enjoy a bit more than the stock set up provided, that my wife would still ride in. And, it is.
  5. mrntd
    Originally I wanted to get the TSWs made they weren't being made at time.
    I was thinking it was probably the struts. Now I have to figure out what to get to keep a good ride and improve the handling. I don't do any track time only back roads in southern Ohio so track oriented struts aren't necessary.
  6. Metalman
    I went with the Swift springs at around 12k and kept the OEM dampers so not many miles on it...
    The change improved the ride and handling... I now have about 25k on the MINI and have no issues...
    I suspect your dampers are the culprit Nick...
  7. mrntd
    Yep. I just wanted a second opinion. It only has 45k but they are 11 yr old.
  8. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Yeah, those shocks are likely toast after 11 years.
    Re-pair them with some Bilsteins and I think you'll be a very happy camper.
  9. Dave.0
    Just contact Colin for deal on coil overs. :Thumbsup:
    (You know you want them) :devil:
  10. mrntd
    My wife would never ride in the car again. I do need to keep the ride reasonable on our carpy roads
  11. Dave.0
    It's all about how you are setting up the shocks (They are adjustable) and the Swift spring rates you select. You can make the car ride like a old Caddy or a Track car. :idea:
  12. Metalman
    And Nick.... If you don't buy em.... Your Nickname with be Genick......:D
  13. Dave.0
    :lol::lol::lol::lol::lol::lol::lol:
  14. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    The Bilsteins should be supple and firm but not stiff and harsh.
  15. BlimeyCabrio
    My current setup on the ridiculous GPR isn't harsh at all, even with full black bushings, huge swaybars, and Colin's coilovers.
    But my wife will NEVER ride in it, anyway. BONUS!
  16. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    I think that as enthusiasts... we have a different idea of what 'harsh' is.
    I have people tell me a stock Cooper rides stiff. :crazy:
  17. mrntd
    I'll have to check into it all when I get back from the Dragon. No time to do anything about it before hand.
  18. BlimeyCabrio
    Tons of cars with different suspensions you can ride in at MOTD.... Just sayin'...
  19. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    Yep.
    I decided on H&R street coilovers and I'm VERY happy with them. Supple, smooth, quiet, and exactly how I like it.
  20. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I wouldn't recommend letting him in your car...
