2nd Gen R56 Cooper S Tail light warning
Discussion in '2nd Generation: 2007+ R55 through R61' started by schmuelkof, Jul 6, 2010.
  1. schmuelkof
    schmuelkof New Member
    Aug 20, 2009
    I get this warning light, telling me a light is out. Sure enough, my reverse lamp isn't working. So I replace it. It still isn't working. Dealer is an hour drive. Anybody have any ideas why my reverse light isn't working (only on one side).
    Thanks.
  2. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Maybe the bulb you replaced was done as well...did you use the bulb from the lamp that WAS working? That way you discount any broken wires...
  3. AXO
    AXO New Member
    Nov 25, 2010
    91
    Wellington, Florida
    My 08 MCS has the same problem! Did you ever find a solution.
  4. Justa Jim
    Could there be two out (like a turn signal or fog light) and you have not noticed the second one yet?
  5. lotsie
    stagehand/part time detailer
    Right here
    Way back in the dark ages when I got my 03, one of the brake lights stopped working about 2 weeks after I got it. Tried new bulbs, did not help, turns out it was the Body Control Module that had gone bad, dealer put in a new one. Your 2nd gen does not have a Body Control Module, but it has something similar, just can't remember what it's called now a days.
    Mark
  6. Metalman
    Maybe......
    Brake Control Module? :D
  7. lotsie
    Right here
    Just thought of something else, on my 03 the reverse light (single lamp) stopped working, turned out it was the switch on the tranny, the only switch on the 1st gens that is NOT controlled through the Body Control Module. Not sure if this is the case on the 2nd gens though.
    Mark
  8. lotsie
    Right here
    Nope:Thumbsup:
    Mark
    Lucas part?
