1st Gen R53 Cooper S Tensioner Replacement
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by wzabrouski, Dec 7, 2010.
  1. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    #1 wzabrouski, Dec 7, 2010
    Does anyone have a DIY for the replacement of the belt tensioner? I change my own belt, so any input after that. It appears to be 4 bolts that need to be removed?
  2. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Search around for the supercharger pulley installation how-tos. Follow the directions up to the removal of the tensioner, then reverse. Find a how to that doesn't instruct you to use a 'quick' removal tool, where you don't have to pull the tensioner.
  3. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Basically you need to compress the tensioner (with tensioner tool/bar) and put a pin (I used an allen wrench) in the retaining hole (holds the tensioner compressed), remove the bolts, remove the tensioner. Install the new compressed tensioner, compress a little more with Tensioner Tool (Bar), remove the retaining pin, release tension.
  4. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Yes, four bolts, two big and two little.
    A few tips: use something disposable to lock out the old tensioner arm like long bent nail, if you use the factory tool or your favorite allen wrench, it will be difficult to remove off the vehicle and spring tension will send parts flying, remove the wheel and well liner for better access, a ratcheting box end is useful on the supercharger bolt, and if it is an automatic you may need to raise and lower the engine to access the two 10mm bolts, use anti-seize on the bolts for easier thread-in with fingers.
  5. wzabrouski
    32
    Executive Director
    Keller, TX
    New compressed tensioner? Does it come compressed? How do you compress if it is off the car?
  6. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    The tensioners I have purchased (various cars) came compressed with a pin holding them compressed. Otherwise the spring has a lot of tension but you should be able to compress in a large vise or with a large C-Clamp.
  7. BThayer23
    Just to clarify, the spring is what causes the tension. The black "tensioner" is actually a dampener that is not under tension or compression, it just resists high frequency vibration.
    Tensioner assembly (with DT tensioner stop installed on top of the "tensioner"/dampener):
    Note: the thin steel piece inside the spring that has the holes in it has a half twist at the end that retains the spring. I removed the pin from the retainer and relieved most of the tension on the spring prior to removing the tensioner assembly. The retainer isn't that burly, so be gentle.
  8. wzabrouski
    32
    Executive Director
    Keller, TX
    There is nothing else that would be causing the belt to slip? When I replaced the new belt a couple of days ago, using the tensioner tool it felt tight?? I am assuming the tensioner is going, but how does a spring "go"?? This is the second new belt I put on with the same issue.
  9. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Are you sure you are using the correct size belt?
    Is your car a JCW?
    Do you have an aftermarket supercharger or crankshaft pulley?
    What brand and part number belt are you using?
    Did you use the same brand and P/N belt both times?
    How many holes are showing on the belt tensioner retainer (coming out of the spring)?
  10. wzabrouski
    32
    Executive Director
    Keller, TX
    Yes, correct belt. 17% pulley with Gates k060535 belt. One hole is showing.
  11. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Why do you think the belt is slipping?
  12. wzabrouski
    32
    Executive Director
    Keller, TX
    Screeching on the gas
  13. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Are you sure it is not a bearing going bad on one of the accesories or various pulleys driven by the belt. Maybe even one of the bearings on the belt tensioner.
  14. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    I had to have my tensioner replaced, but it was only squeaking under idle (at least as far as I could hear). I was putting on a new pulley and belt too, so it all kind of worked together. Good luck!
  15. wzabrouski
    32
    Executive Director
    Keller, TX
    Way sent me a tensioner overnight. Figured I would start here.
  16. wzabrouski
    32
    Executive Director
    Keller, TX
    Screeching only on heavy gas
  17. BThayer23
    Could be a bad idler pulley. Remove the belt, spin the pulley, and check for play.
  18. wzabrouski
    32
    Executive Director
    Keller, TX
    Which is the idler pulley?
  19. wzabrouski
    32
    Executive Director
    Keller, TX
    I can drive lightly and I get no squeal. When I give it gas hard, I get the squeal. I get the squeal.
    Funny part is that I had no issues until I changed by last belt at 20k. It was not squealing at all, but I figured I would change it before winter...
  20. BThayer23
    The idler pulley is the small pulley that just bolted to the block. It's shown here to the right of the bigger crank pulley.
    There's not a lot of stress on the serpentine belt until you get into positive intake manifold pressure (boost). I busted my crank pulley - separated the inside from the outside - but managed to drive it home gently.
