1st Gen R53 Cooper S Testing a Wheel Speed Sensor?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by rum4, Jan 30, 2014.
  1. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Trying to help a friend out with his 2006 Cooper S. What's the best way to test the wheel speed sensors?
    I don't know, I did change the title to something a bit more in line with the subject matter in order to draw more views for you.
    I don't think there is an easy shade tree way. Me thinks you have to have someone with the proper computer thingamajig diagnose that for you.
  4. ScottinBend
    If it is bad it will generate the error lights on the dash, if not then it is working. Only thing I have ever seen done was to clean up the sensor as they can get dirty and cause intermittent faults.
  5. rum4
    4,568
    1,475
    SC
    Thanks everyone
  6. RallyMini370
    Seeing as I'm the dumb dumb that removed the senors and ABS I had the use a code scanner to figure out which were good sensors and wiring when I put all the ABS system back. There is a code that shows up for each sensor and when all is well the ABS light should go out....there is a bunch of how too's on Youtube..[ame=http://www.youtube.com/watch?v=nAji_mJsr_w]How to Test ABS Wheel Speed Sensor using the ABS Warning Light! Fix? Repair? Replace? ABS Car Brakes - YouTube[/ame]
  7. MCS02
    Sorry I'm late to the party. I had to have mine put on the BMW computer. It turned out to be the front left. I was told it is almost always the front left. Sorry not much help.
    Now that you remind me, my MINI had to be docked to the mother ships computer too. I was also told it is usually the LF. Couldn't remember the details. Man it is heck getting :sleep:.....
  9. rum4
    4,568
    1,475
    SC
    Thanks
  10. Dave.0
    I have been resisting saying take the car out and speed and see if it tells you to slow down. :lol:
  11. RallyMini370
    Saying that I still have the ABS light on.....due to I don't have the ABS pump, just the module bolted to the heater box. All I needed was the speedo working for the tech test for the street. I barely look at the speedo as I know I'm going bloody fast..hahaha
  12. Dave.0
    Easy fix:
    Take speedo out.
    Put a small piece of 3M black electrical on back of ABS light.
    Put speedo back in.
    No more stupid light to draw others attention. :D
  13. RallyMini370
    That's a good idea Dave. I have the ABS, brake abd low tyre pressure lights on. Another little job for the weekends.
    You have the trifecta Chris. You know what that means? Three pieces of tape. :D
