1st Gen R50 Cooper The Horns are ALIVE! But my MINI is dead?!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by SNEEEZY - Erika, Oct 6, 2011.
  1. SNEEEZY - Erika
    1,212
    116
    Female
    #1 SNEEEZY - Erika, Oct 6, 2011
    MINI is DEAD...but horns are ALIVE?!
    Ok...I recorded a soundbite of the Hellas and then decided I was going to grab a bite to eat from Burger King...
    The horns sound A-W-E-S-O-M-E but now I get a lot of clicky-clicky when I try to start the engine...
    What happened?
    [ame="http://www.youtube.com/watch?v=WKBcYwOAXag"]http://www.youtube.com/watch?v=WKBcYwOAXag[/ame]
  2. SNEEEZY - Erika
    1,212
    116
    Female
    Failed at linking video...
  3. SNEEEZY - Erika
    1,212
    116
    Female
    Failed at video upload x2...
  4. Metalman
    Sounds and looks like a pinball machine....
    I wanna hear those Hellyeahs....:D
    Congrats..... Weak battery?.... Hook up a battery charger???? Maybe
  5. SNEEEZY - Erika
    1,212
    116
    Female
    Schultze is my daily driver and I need to get him up & running so I can get to the office in the morning...
    I just don't understand what I could've done to cause this newest problem aka the car not starting.
  6. SNEEEZY - Erika
    1,212
    116
    Female
    Oh, it would certainly be just my luck if the OEM battery went to crap JUST as I got the horns to work...
  7. SNEEEZY - Erika
    1,212
    116
    Female
    Jumped Schultze with the GTI, then drove to the gas station, filled up the tank, and drove a little bit longer.
    Guess it's time to start doing some research for aftermarket batteries...
    On the UP side...the Hellas are L-O-U-D...especially when you are driving through an empty shopping center parking lot...the echo is even sweeter!
    It is very likely the oem original battery has gone tango uniform on you. It could be having your MINI laying on its left side also caused a problem. Put it back on all 4 wheels.
    Sounds like it is cranking slow. As Metal/Chuck said check the battery.
    Congrats on the horns!!! :D
  9. SNEEEZY - Erika
    1,212
    116
    Female
    You have NO IDEA how hard it is to look graceful while trying to start a car, hold a cellphone camera & balance a car when it's on its side!
    I don't know WHY the video came out that way...I was truly holding the camera vertically.
  10. Rae
    Rae Club Coordinator
    Oct 14, 2010
    907
    Oregon
    I still think you need to call an exorcist :)
  11. agranger
    1,486
    Did Erika just say that she is finally horny? (sorry... someone had to say it)
  12. Zapski
    There's your problem. Video is meant to be landscape, not portrait. :)
    Good to film the issue though, I did the same thing when I was having the cold start rattle. Made a DVD of it and took it to the dealer when I dropped off the car to get it fixed.
  13. DneprDave
    #13 DneprDave, Oct 7, 2011
    Maybe the horns are too big and they sucked all the smoke out of the battery!:)
    What did you have to do to finally get the horns working? Was it a bad ground?
    Dave
  14. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    #14 Norm03s, Oct 7, 2011
    This sounds too coinsidental to me. What is 87a on the relay connected to?
  15. SNEEEZY - Erika
    1,212
    116
    Female
    It was definitely a bad ground. I had to run two new ground connections and I simply used the OEM horn "hot" wire.
    I haven't installed the relay yet.
  16. Mr. Jim
    Maybe she needs this......
  17. Norm03s
    Norm03s New Member
    534
    Lucas the Prince of Darkness
  18. Norm03s
    Norm03s New Member
    534
    Lights or wipers, but never both.... :D
    Lucas = Loose Unsoldered Connections and Splices :p
  20. Sideways
    Sideways New Member
    May 12, 2009
    539
    37
    Above the Border^^^
    Maybe your MINI just got all light headed from tooting all day...
