3rd Gen This is going to be the HP MINI
Discussion in 'Tuning and Performance' started by wjosh45, Feb 1, 2018.
  1. wjosh45
    wjosh45 Member
    Nov 20, 2016
    131
    Man.. with just some software changes, this is going to be the car to have if you want to make power... 300HP on software alone.
    Anybody have this tune (or another variant)?
    That is some good gains.
  3. Dave.0
    Yawn,,,,, sorry but no it’s won’t. The F56 basic block, pistons, rods and turbo cannot handle that HP for long.
    You may get a “Hail Mary” dyno run or two but that’s about it. It will not be reliable.
    • Like Like x 1
    • Disagree Disagree x 1
  4. Dave.0
    Nice 80 glasses ......
  5. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    I’ll have to do some more research.. from what I’ve read so far, it appears they hold up somewhat well to tuning. That said, I’m basing that more on what I’ve seen from the BMW side.
  6. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    One could always just buy a car with 300 horses stock. Js.
  7. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    True - there are options out there, but not of the MINI Variety.
  8. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Impressive gains for just a reflash/tune.
    I already have traction issues stock. I can't imagine what would happen with more torque.
    The engine internals can take the tune just fine. The issue that seems the plague the hard 93 oct tune is the clutch not being quite enough to hold up to the torque.
  9. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Really.. interesting. Does it slip or does it tear itself apart. BMW has a history of putting a valve combined with a clutch plate that essentially slips the clutch in. Makes it easier for folks who don’t really know how to drive a clutch but destroys the clutch over time. My 03 M5 is a good example. Hard to get more than 70K miles out of a clutch. Its the only car I’ve ever had to replace one on. Needless to say, that valve is gone. Wonder if the F’s have this.. hell wonder if my R56 has it. I need to look into that as the clutch doesn’t really have any “feeling” to it.
  10. Redbeard
    1,636
    398
    #10 Redbeard, May 21, 2018
    What I have seen posted is the clutch while engaged with the flywheel under the hefty torque will slip.
    Also if the clutch in the F56 is similar in size to the R56 then that is a TINY clutch. Not a whole heck of a lot of surface area for contact.
    My R56 had a sprung clutch plate and a dual mass flywheel to help with smooth engagement. Not sure of the F56 is the same setup or not. Feels similar.
  11. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Ok - so it slips under power.. I’ll have to look into that some since a 3rd gen is what I’m looking at.. what type of power does it take to create this situation?
  12. Redbeard
    1,636
    398
    Well from the comments (no personal experience mind you) over 350 ft-lbs seems to be about the threshold. However, I think that has to do with how hard and fast the torque comes on. Based on NM/Bytetronik/Evolve tunes that have been posted about.
    Bytetronik is about 15 mins from my house. Might be worth giving them a call. I bet they can tell me at what point clutch slippage is an issue.
  13. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Anything 350+ on a front wheel drive car is kinda pointless. You won't get grip out of a corner or off the line. Sure my R56 could use a flash tune to get a few more horses out of it, but she doesn't need much. Maybe 50-70 more would be perfect.
  14. MCS02
    R53 stock clutch is strong and I think the R56 is too, at least I have never heard anyone complain. Now that @Sully has a R56 we will see if they can stand up to abuse.:D
    • Like Like x 1
    • Funny Funny x 1
  15. Dave.0
    OS GIKEN twin disc clutch will handle anything you can throw at it. I think they only make it for R53’s and R56’s but I am sure they will come out with the F56 version soon. While you are doing the clutch should replace the crappy OEM LSD and the OS GIKEN super-locker LSD for $1,750.00. I love my OSG LSD over the crappy OEM LSD. This way your trans will be bulletproof as long as your motor stays together.
    The OSG twin disk is rated for 550 + HP so I am sure a MINI will not be an issue no matter how much HP you make.
    You can google them and expect to pay at least $1,700.00 to $2,000.00.
