2nd Gen R56 Cooper S Throttle issue?
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Jul 14, 2015.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    At indefinite moments, i get bad throttle response, or should i say that there is no response despite i step on the pedal. The error code given is the P2102 (before a few weeks the P2103 also had come up), any idea what that actually is? Torque says its "Throttle Actuator Control Motor Circuit Low" but i have no clue what that is!
  2. Zapski
    I'll check my Bently manual when I get home. It may not help much though.
  3. Zapski
    Bentley say both codes mean "Throttle Actuator 'A' Control Motor Circuit High"
    So... Yeah. Not much help.
  4. Zapski
    Reading a bit about the throttle here. You have an S, right?
  5. genik
    genik Member
    Feb 20, 2012
    402
    19
    yes it is a 2008 R56S
  6. Zapski
    OK, so same as mine. :)
    The throttle is electrically linked to the accelerator pedal.
    Here's what Bentley says:
    The rest is how to replace the throttle housing unit.
    So it sounds like you might have a faulty set of sensors?
  7. genik
    genik Member
    Feb 20, 2012
    402
    19
    So i guess now my two main issues are
    1. how do i replace the throttle body, which i have no clue in how to do so! Is this described in the Bentley manual?
    2. which part no. is the throttle body described in real oem?
  8. Zapski
    Here you go.
    It's the best I can do. :)
  9. nkfry
    nkfry New Member
    Roseville, MI
    You are going to have to back probe to verify whether the issue is wiring or throttle body. I have never seen an issue with wiring, but problems vary per geographic location.
    I have only replaced one throttle body, and it was because the shaft for the butterfly had begun to allow condensation and oil past and into the throttle body electronics. Upon opening the throttle body I found about 2 oz of oil, and broken teeth on the potentiometer gear.
    Replacement takes us about an hour, if you have the proper tools on hand it may take you 2-3 based on skill level.
  10. genik
    genik Member
    Feb 20, 2012
    402
    19
    How will I make verification between wiring or throttle body?
    Can the throttle body be opened and then closed again to work?
    What tools are needed and are there any tutorials one can consult,before unmounting or even replacing the throttle valve?
  11. nkfry
    nkfry New Member
    Roseville, MI
    A Bentley Manual is going to be your best investment, next to oil changes every 5,000 miles.
    I highly recommend AGAINST trying to open the throttle body, there is small Torx screws and a heat applied glue that holds it together. The chances of you breaking the body are very high, and with what you are saying a new throttle body will be the "part" to fix it.
  12. genik
    genik Member
    Feb 20, 2012
    402
    19
    #12 genik, Jul 15, 2015
    Can it be fixed without opening it?
  13. genik
    genik Member
    Feb 20, 2012
    402
    19
    Can someone tell me the Throttle body part number for my 2008 R56S in real oem, cause im mixed up in finding it?
  14. nkfry
    nkfry New Member
    Roseville, MI
    MINI P/N is: 13-54-8-624-189. Don't try to open up your existing TB to fix it. It is a sealed unit, the only reason I was able to open one is because I was able to diagnose that it was the fault and had replaced it with a new unit.
    Feel free to give us a call and we can get you one on the way: 586-792-6464
  15. Dave.0
    The OP is in GREECE not the USA.
    Just buy a new OEM TB and replace it or have some one do it for you.
  16. genik
    genik Member
    Feb 20, 2012
    402
    19
    Has anybody seen any tutorial regarding this replacement?
  17. genik
    genik Member
    Feb 20, 2012
    402
    19
    Finally i took it to a tech, he removed it and found out that the valve would not open/close when pressed manually with his bare hands! It was the mechanism that was faulty, that's why the valve would not turn when pressed. 2 out of10 times when pressed it would turn, the rest, it would stay stiff!
    Replaced it and so far so good.
    One question though, is your throttle body plastic or metal and does its say VDO on it?
  18. Zapski
    Dunno, I'd have to take the bloody thing to find out. And that's not gonna happen unless I need to.
    Glad to know it's been fixed :)
  19. ZippyNH
    Good to hear it is fixed...
    Now get out and DRIVE!!
    YOU BOUGHT A MINI TO ENJOY!!
