2nd Gen Tips & Tricks
Discussion in 'Car Builds, Projects, Idea's Experiments' started by AliceCooper, Jun 24, 2012.
  1. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    There may already be a thread for this or a different section( maybe DIY) to post this in. Anyway I always like to hear tips and tricks on doing things that make DIY jobs easier. Will start this thread with this :
    In an effort to keep my K&N cleaner and make cleanings easier, I use women’s knee high stockings. Just slip one (or two) over the cone and it keeps the large debris out of the ribs. (borrowed this from a post on GRM)
    Would love to see more tips..:cornut:
  2. Metalman
    Found this on the interwebz yesterday to recalibrate the speedometer.
    If you turn ur key to the second setting on your ignition and then press the black button that controls time and trip millage it's puts the car in test mode which is very useful for calibations and resetting stuff if things freeze or tempory pack up. To do this press the black button so you see the trip distance hold the button Down for lit 15sec first the distance travelled will re-set then then you will see it say TEST now release and then press it again and you will see TEST 2 leave it and watch all ur dials go on a madness lol if u want u can take a pic of the speedo at 150mph lol and claim u hit it lol (pathetic but can be done lol) this will not harm your mini and yo cancel simply take ur key out. I used this to reset my friends speedo clock.
  3. Justa Jim
    Cool. How do I turn my key to the "first position"? :lol:
  4. Metalman
    #4 Metalman, Jun 24, 2012
    My MINI just told me its birthday.... Never knew the day, only the month and year.
    So it's a Friday build.... Better than a Monday build I guess??
  5. Metalman
    Not gonna tell you Jim....:D
  6. ScottinBend
    Best hint ever for changing oil on the first gen cars.......press the filter into the housing firmly so it enlarges the hole on the bottom then put it into the canister. Makes it so much easier to get the filter screwed on.
  7. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    Any idea how to do this on an R56?
  8. Metalman
    Unfortunately it's a R53 thing.....
  9. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    Hmmm thanks....
  10. Justa Jim
    Now you tell. I spent the last hour trying to turn my key fob. :mad2:
  11. Metalman
    Snicker Snicker Snicker....:D
  12. ScottinBend
    Better than trying to turn the start button ! ! !
  13. Nathan
    If not careful you might end up with a ʇɹɐʇs button.
  14. docv
    docv Well-Known Member
    818
    280
    moble auto paint tech ( PTU )
    Central Missouri
    Was hard to print that upside down wasn't it Nate....:biggrin5:
