Brakes Wheels 3rd Gen Tires Tire Rub on Suspension
Discussion in '3rd Generation: 2014+ F54, F55, F56, F57, F60' started by OneGreatZero, Oct 8, 2017.
  1. OneGreatZero
    OneGreatZero New Member
    Oct 8, 2017
    I recently returned to MINIs by purchasing a 2015 4-door base Cooper (needed the better gas mileage than my Benz) with the stock little 175/60/R15 wheels. I then purchased a set of OEM MINI Clubman 225/40/R18 set of wheels. It did not even cross my mind that there would be a fitment issue, since they are OEM. The wheels hit hard on the strut tower in the front, and the lower suspension arms in the back. I'm guessing spacers, obviously, but how much, and is there any other concerns I may have overlooked? Suggestions?
  2. GokartPilot
    GokartPilot Well-Known Member
    Jan 9, 2012
    970
    732
    training specialist
    Maysville, North Carolina USA
    18" seem to be a pretty big jump from 15", most here have found a happy medium equals a 17". I am not a suspension guru by any stretch of the imagination but you if you start adding spacers you are going to push the tires out of the wheel well, ending up with ride height issues.
  3. 00Mini
    2,264
    Sorry I don't have any expertise in area of suspension modification but the wording 'hit hard' doesn't sound minor but I can Welcome you to Motoring Alliance !!
  4. OneGreatZero
    Oct 8, 2017
    Well, I have the wheels, and want to effectively make them work. Heightwise, they are fine. Only about 1/2" taller. I was just curious if anyone has run into this same situation, and looking for recommendations on spacers. 5mm, 10mm, 15mm... I know they will push outward, but I'm not going to have an issue with the wheel well rub, just wanting to correct the suspension rub. I was surprised to have run into this. Never had rim issues with any of my Benz's, other than brake diameter restrictions.
  5. wmwny
    4,040
    2,242
    Welcome to M/A! :Thumbsup:
    I'm sorry to not be of any help, as my 3 MINIs run 15", 16" and 17" wheels...depending on the seasons. Also, my MINIs are all Gen 1s and i think the bolt patterns are probably different from the 4 bolts I have on my wheels and I am totally illiterate on the use of spacers. :nonod:
    Even so, again, welcome to our MINI corner of the world! :cornut:
  6. OneGreatZero
    Oct 8, 2017
    I am quite surprised that I am the first person ever to have run into this. Searching the web and everything.
  7. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    your wheels most likely have the wrong offset for their width. That means they are too deep in the wheel well. Diameter issues would cause fender rubbing, not inside issues on the struts or suspension pieces.
    When rims get wider, e.g. from 6 to 7 inches. their center needs to be moved more to the outside, otherwise they "grow" towards the inside where those parts live you don't want the tires/rims to rub. Adding a spacer can move the wheels further out, but you need longer wheel bolts (or studs if converted to studs)
    Here's a good overview of what's going on - read especially the part about offset
    http://www.moderntiredealer.com/article/312133/an-installer-s-guide-to-wheel-offset
