what would be a recommended tire size for an 02 R53 with 17in Team Dynamics Pro Race 1.2 rims? thanks!!
:cornut:I like 215 x 45 R17s but most people around here are much more knowledgeble than I am and they'll be here shortly. Jasonopcorn:
Assuming a 7 inch rim: Stock size is 205/45/17. I like 215/40/17. Slightly wider with a shorter/stiffer sidewall making for a more precise response. If you are not lowered and depending on the offset, 215/45/17 should work resulting in slightly softer ride.
I run 215/45 to keep my speedo reading correctly. For track tires I wouldn't caer though. The shorter profile gives you a gearing advantage as well.
215/45-17s here. Keep in mind not all tires from different makers are the same size. Width wise anyway..
