1st Gen Tire Warning Light On
Discussion in 'Starting Line - New Member Introductions' started by cockney, Nov 29, 2011.
  1. cockney
    cockney New Member
    Oct 5, 2011
    16
    Hi
    Ok i hate run flat tires, i find they do not stick as well as regular tires and the ride is a little harsher. So when i needed 2 front tires i put on regular tires, one step towards replacing the rear tires after the holidays.
    Would this cause the tire warning light to come on. Checked the pressures etc.
  2. BThayer23
    What year and model is your car? The first gens use an indirect TPMS while the second gens use a direct TPMS (tire pressure monitoring system). Bottom line, no, unless the tires are under-inflated or different sizes.
  3. Friskie
    Friskie Well-Known Member
    Jul 20, 2009
    1,650
    1,333
    Highly motivated retiree
    In the here and now, for now.
    To know just how to advise you, the year and/or R## of your MINI is needed, i.e. rotation sensors or pressure sensors. If you have rotation sensors, tires of different types could cause it to throw an error. Stand by for the tire guru to jump in on this.
    Be aware that runflats on one axle & regular tires on the other alxe may make for some bookie handling. Proceed with caution.
    Tire nanny's hate them... :mad2:
