Brakes Wheels 2nd Gen Tires Tires with Squared Tread look Fatter
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Nov 29, 2015.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    Hello, im interested in purchasing a tire for my R56S that will have the most squared tread available so it will give the look of a fatter tire. Right now the car is wearing the Continental Conti Sport3 tires, but their tread is curved and from the rear, it looks like a thin tire. What options would you give me for tires in order to look fatter than the ones i have now? The size is 205.45.17
  2. rkw
    rkw Well-Known Member
    443
    If you're looking for fat, go to 215 or 225.
    These hand grooved Hoosiers have that look you desire.
    You don't need wider tires you need wider rimz.....
  5. rkw
    443
  6. mrntd
    When your looking at tire specs look at the tread with for the size you want. BFG usually has pretty wide tread.
  7. DneprDave
    BFG= BF Goodrich
  8. Metalman
  9. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    I've had the Benjamin Franklin Goodrich G Force Sport Comp 2's and they are fantastic. And have squared edges :) Boom...
    Also, Going from a 205 tire to either 215 or 225 will give you these squared edges you're longing for.
  10. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
