Torque Pro or Dash Command
Discussion in 'Garage Talk :: Tool, Tips and Maintenance' started by ScottinBend, Nov 12, 2015.
  1. ScottinBend
    Considering these apps for my Android.....
    Any thoughts?
  2. ScottinBend
    Still thinking about these.......any one use them?
  3. MCS02
    6,317
    Wish I could help but I have an iPhone. But I have used Dash Command and it seems like a good app.
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    I use Dash Command and I like it alot.
    Here's a screen shot of the MINI dash they offer (not connected in pic):
  5. ScottinBend
    Which obd sender are you using?
  6. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #6 Qik, Jun 8, 2016
  7. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Here it is connected
    54FFE3FA-64BE-470F-9F43-DAFB24754C34_zpsncziul5e.png 57940A02-16F4-4849-AF17-DF68BE268BEE_zpswkzg0gd7.png
  8. cerenkov
    cerenkov New Member
    Mar 6, 2014
    67
    30
    Nuclear Engineer
    Wake Forest, NC
    I also use Dashcommand with an iPhone. The display that I made is all numbers so that it is really easy to
    read.
  9. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Anyone using this with an R53?
  10. DneprDave
  11. ScottinBend
    If it's wifi, it should work just fine.
  12. ZippyNH
    Almost gone down this road a few times....keep jumping back and forth between a wired unit, and the phone ones....
    My thoughts....
    The WiFi adapters are worth the extra money if you ever use Bluetooth in your car....keeps that option open....since Bluetooth profiles tend to usually only one paired item.... sometimes you can have more than one, but issues can crop up.. wifi should be plug and play....and still let's you use Bluetooth to connect with your car/and or earpiece.
