3rd Gen F56 Cooper S Torque values
Discussion in '3rd Generation: 2014+ F54, F55, F56, F57, F60' started by MGBILL1186, Jul 9, 2015.
  1. MGBILL1186
    MGBILL1186 New Member
    Apr 26, 2015
    13
    Hi all! Quick question on torque settings for the drain plug on the oil pan and oil filter canister? Also torque settings on the lug nuts. All help is much appreciated.
  2. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
    for a gen 1, R53
    Engine oil drain plug to oil pan: 25Nm (18ft-lbs)
    Cover to oil filter housing: 25Nm (18ft-lbs)
    I use 98 ft-lbs +/-2 on OEM lug bolts.
  3. MGBILL1186
    Apr 26, 2015
    13
    Thanks for the info....the manual that came with this 2015 MCS is woefully lacking in pertinent info. I asked the service rep for the correct values and he didn't know, said he could go ask a tech but was too busy at that time. Guess I'm going to have to buy a Chilton type manual. Thanks again for your input, it sounds about right and gives me a good starting point.
  4. CHKMINI
    The wheel lug value is higher for the R56 and F56. That value is listed in your owners manual.
    For the lug nuts...
    103 ft/lb or 140Nm
  6. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Don't bother with a Chilton, or Haynes type manual. Bentley is the way to go. Not cheap, but worth every penny. :Thumbsup:
  7. MGBILL1186
    Apr 26, 2015
    13
    thanks for the info guys. It's nice to have family to fall back on when straight scoop is desired!
  8. Dave.0
  9. Desy232
    Desy232 Banned
    Dec 4, 2017
    10
    Thank you for the good advice guys
  10. agranger
    I thought that the R53 lug bolts were 78 ft-lbs. The oil drain and filter housing I'm not sure... I always just did 1.5 grunts as, especially for the filter housing, it's hard to get a ratchet handle on there, let alone a torque wrench.
  11. Zapski
    For the gen 2 R56 (not your model but we might as well have everyone represented here)
    Oil Drain plug to oil pan - 22 ft-lb
    Cover to oil filter housing 18 ft-lb
    Though I’ve traditionally done the hand-tight and then just a bit more for the filter housing.
  12. Canusrufis
    208
    103
    Winston Salem NC
    I'm going off BMW TIS 36 10 1AZ spec for M12 wheel bolts, 120NM. 140NM is for M14. But, grunting might be ok too. And somehow this is a 3rd gen forum.
  13. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Filter can holder thing 25Nm, and drain plug to 30Nm. The lug torque spec should be in your owners manual but it varies by year. Mine is something like 103.2 ft. lbs.
  14. agranger
  15. MCS02
    6,319
    First this is a dead thread its 2 years old. Second it is under " 3rd Generation MIN" topics, look at the top, this is what Canusurfis meant. But most of all this was resurrected by some guy that joined and than posted the same thing to 10 non-related threads.
    No one is turning this into a mini war everyone was posting specks to different gens under the gen3 forum. to help a guy that did not ask a question. I am glad we are trying to help but good grief. Look at all of Desy232 post.
  16. QXXOTIC
    QXXOTIC New Member
    Jul 1, 2009
    Retired Product Development Specialist - Consumer
    San Diego & Ventura County Ca.
    R-53 Lug bolt torque specs
    With the earlier R-52 with the 12mm bolts, the correct torque is 88 Ft lbs. Slightly more with the later 14mm bolts.
