Brakes Wheels 1st Gen Tires TPMS sensor question
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by GreenMiniClub, Apr 10, 2012.
  1. GreenMiniClub
    GreenMiniClub New Member
    Mar 3, 2012
    62
    So I have noticed everyone switching to their summer tires. Do you have 2 sets I sensors or have to swap them? I am needing to get new tires and currently have all-seasons, I was considering getting wheels and summer tires and then winter tires in the fall on my factory wheels. If you are running 2 sets where is the best place to get them? Thanks
  2. CHKMINI
    Tire Rack.com
  3. Minidave
    4,592
    Don't swap them, buy another set of wheels and new sensors.
  4. ScottinBend
  5. agranger
    1,486
    Yep... to swap sensors means that you will probably have to remove (or at least mostly remove) the tire from the wheel. I've heard that doing that too often will weaken the tire... probably not a great thing.
    If you want a set of winter tires/wheels, buy a new set of sensors. I think that a new set will run you around $150-200, but will make your life much easier and, once you have the sensors/tires mounted on the new wheels, switching back and forth can be done easily in your driveway. Just be sure to clean and dry the old wheels before you put 'em into storage (and a coat of wax wouldn't be an awful idea).
    What happens if one runs wheels & tires without nanny sensors in them? God awful goning??? Or blissful silence?
  7. Mr. Jim
    I would say it would turn on the tps light on really really bright! :)
    If it is the one in the pie plate speedo it would be OK. If it is the one in the tach it will be a problem. I plan on buying a set of winter tires for Babs clubster. I really do not want to pay for $225 worth of sensors if I do not have to.
  9. ScottinBend
    Black tape works wonders..........
    Yes black tape does work wonders. If it was my car it would be OK, but since it is my wife's not so much.
  11. KittyMini
    KittyMini Club Coordinator
    1,183
    DEFINITELY get another set... you always run the risk of breaking the valve stem taking them in and out. Plus it's just easier to not worry about it every time you swap your wheels and tires.
    TireRack or OutMotoring sells them... that's where I got them for my R56.
    LOL- still have them in the summer set even though I don't need them.
  12. canucc00
    canucc00 New Member
    Jan 1, 2012
    22
    Gurnee, IL
    Ran for a weekend without the TPMS on my wheels. No noise just the warning lights on the speedo and tach.
  13. ScottinBend
    So just use pink.........:biggrin5:
    Have some I can borrow? :wink:
  15. Minidave
    4,592
    Ran mine like that for a year, after a few minutes you don't even notice the orange light - it blinks for a few moments when you start the car, then it's on steady from then.....no gonging except on start-up, like usual.
    Eventually I went ahead and got the sensors when I put new tires on those wheels. The system in my '09 Clubby is pretty cool, it not only tells you when you have a low tire, it tells you which one!
    Our 08 does not tell us which tire, but I do know how to use a tire gauge. :wink:
    When we picked up a horseshoe nail it lit up, but I had to find the tire. Not easy to look at with those gosh darned runflats. When I put one of my snow tires on to drive to the tire store for the repair I got a warning in the tach that said system failure or some such. After a bit that stopped & the one in the pie plate stayed yellow.
    Knowing Babs she will want the sensors because it is the right thing to do.
    Thanks for the reply Dave.
  17. KittyMini
    1,183
    Weird.... I don't remember my '09 showing what tire, just the light would come on :confused5:
  18. Minidave
    4,592
    Did you have A flat, or was it one of those cold night all the tires are lower than when you shut it off deals? Cause I get those anytime the weather changes substantially - which it does around here ohhhhh, every 30 minutes or so....:wink:
    After the first dozen or so times I've learned how to reset both my R53 & Babs R55. :eek: Yep temp changes seem to get the tire nanny out of sorts.
