Brakes Wheels 2nd Gen Tires TPMS
Discussion in '2nd Generation: 2007+ R55 through R61' started by Flyboy, Sep 15, 2014.
  1. Flyboy
    Flyboy New Member
    Aug 23, 2014
    Airline Pilot
    DFW, Texas
    Shopping for tires and they want to add a TPMS rebuild kit into the price (Discount Tire). It is 7.50 per wheel for an extra thirty bucks on top of the tires. Is it a good idea to go ahead and do that for $30...or a waste of money? I only have 21,000 miles on the Mini...wondering if the TPMS really need a "rebuild" every tire change.
  2. Metalman
    Well....
    You can't change the battery (non serviceable item)...
    So they must be trying to get you for new sealing washers where the nipple goes through the wheel... The only other pieces are the Schrader valve and the cap and probably some labor...
    Rebuilt at every tire change.... Absolutely not...
    Do you always get new valve stems with your non-TPMS wheels???? Probably not...
    The TPMS batteries start going bad after around 6-7 years maybe...
    I'd say they most likely don't need to be rebuilt. The only things they are rebuilding is a new valve & an o ring seal.
    TPMS Rebuild Kits
    Welcome to M/A
  4. Dave.0
    Nice looking Chili Red MINI. :Thumbsup: You don't need them, waste of $$$ since your car is a 2012.
  5. Flyboy
    Flyboy New Member
    Aug 23, 2014
    Airline Pilot
    DFW, Texas
    Thanks all. Kind of what I thought. I'm just getting rid of the run flats and thought I'd get your collective wisdom! I'll put the 30 bucks somewhere else.
  6. Metalman
    Ask them if they have the Whoo Whoo whistle.... Gotta get that...
    [ame=http://youtu.be/Nnzw_i4YmKk?t=33s]The whistles go.... whoo whoo! - YouTube[/ame]
    Roxxanne was nuts before the whistle...
  7. ljmattox
    ljmattox Active Member
    Dec 28, 2011
    223
    123
    IT consultant
    St Louis metro USA
    Likely not necessary. I used to be told, "state law requires..." this service kit, but I haven't found that (for Missouri).
    I've changed tire shops since...it's not been mentioned on my last 4-5 tire mounts here.
    As others have said: sealing o-rings and maybe the Schrader valve are the only wear/age items. New'ish shouldn't require changing.
