Transmission Help
Discussion in 'Starting Line - New Member Introductions' started by blabs, Jun 26, 2014.
  1. blabs
    blabs New Member
    Jun 26, 2014
    Hello everyone. This is my first post. I have an 04 cooper with a growling gearbox. Its the 5 speed. Are there any quick fixes to make it last or am I on borrowed time. If fhe transmission needs to be changed can I put in a 6 speed?
    thanks
    A change of the gear oil may help out. MINI says it is a lifetime fill, but it's not.
  3. Dave.0
    Welcome to M/A the FUN Mini site. :Thumbsup:
    Try a Fluid flush first
  4. MCS02
    6,278
    Welcome to MA!
    If you are lucky it is low on gear oil & changing it will be the cure. If not it may buy you time until you have to replace the gear-box. Your car has a Midlands if you change it make sure you put a Getrag in. Not sure if the 6 speed is easily swap-able.
    Welcome to M/A
  6. ZippyNH
    #6 ZippyNH, Jun 29, 2014
    Welcome....
    Yeah...maybe a flush and fill might buy you some time...
    The midlands 5 speed that was used up till the 2005 model year was a bit trouble prone....
    In 2005, mini switched to a getrag 5 speed...used different CV joint/axels...Different spline count...so not sure if these are trurly swappable.... The change to a 6 speed from the s...know it has been done on CVT cooper (auto) cars.... Not sure about the 5 speed.
    Good luck...tons of info around!!
