Transmission needed!!!
Discussion in 'Want to Buy' started by tshstudios, Mar 25, 2013.
  1. tshstudios
    tshstudios New Member
    Oct 27, 2012
    NEED a reasonably priced transmission for my 2003! Please anyone out there - would really appreciate any/all suggestions! Dealer wanted too much for the age of car.... Thanks, Tara (tshstudios)
  3. tshstudios
    Oct 27, 2012
    I believe it is just a cooper not an "S" - it is a R50 - so perhaps that should tell me! Thank you for the recommendation - I will check it out. Tara
    The transmissions in the 2002 - 2004 Coopers use a Midlands gearbox & are not the most robust design. Look for a 5 speed from a 2005 or 2006, Getrag's are a much stronger gearbox.
  5. sethat46
    sethat46 Well-Known Member
    Apr 25, 2012
    1,560
    413
    Financial Sales
    Ohio
    Chuck you should probably explain that the Getrag is the name of the transmission as well as the midlands. So Tara you should be looking for a Getrag from a MINI, they are better.
    Can she put a 6 speed in? Or does it have to be 5 speed?
  6. RallyMini370
    Tara,
    Is this an auto or 5 speed box? If you have a 2003 for sure you have the dear old 5 speed Midlands box which is famous for self destruction. If you go for the July 2004 onwards Ford Getrag box you will need to swap the flywheel,clutch , axles etc. The "S" box is stronger but a 6 speed and again you will need to swap the flywheel, clutch, axles etc. Ebay might have a used box.
  7. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I guess no one brought up the point that it could also be the CVT Transmission. I didn't see where it was specified if it was Auto or Manual...
    If it is a broken CVT the MINI is justa about totaled.
