1st Gen R53 Cooper S Trunk/hood light won't go off
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by lr19, Aug 13, 2016.
  1. lr19
    lr19 New Member
    Aug 12, 2016
    54
    Hello have a 04 mini my trunk/hood light won't go off both are securely shut. Any ideas?
  2. SeanKidd
    SeanKidd New Member
    Sep 8, 2010
    16
    The switch is on the right bonnet (hood) latch, its sticking...a little silicone spay should fix it.
  3. lr19
    lr19 New Member
    Aug 12, 2016
    54
    So just some wd40?
  4. DneprDave
    No, use silicone spray. WD 40 will dry out and the problem will come back.
  5. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    The spray might work but, I could better understand that working if the "button" was stuck closed meaning the light won't come on. Once the hood/trunk is closed the button should be compressed as always and the light turn off. Unless... What I had to do on my '06 cabrio for the boot light to turn off was tape a washer right where it touches said "button" to compress it alittle more and it turned off. Probably a better way to do it out there but it worked for me and I left it like that for years..
  6. lr19
    lr19 New Member
    Aug 12, 2016
    54
    Update got back from a service today and now the lights off lol, not sure if they did something but regardless it's off... for now...
  7. 00Mini
    2,227
    Nice to hear the problem is gone and hopefully stays that way.
  8. lr19
    lr19 New Member
    Aug 12, 2016
    54
    Yup I might put some of the silicon spray just to avoid any issues, I'm assuming it had to just be the latch stuck
