2nd Gen R56 Cooper S Turbo inlet pipe keeps backing out
Discussion in '2nd Generation: 2007+ R55 through R61' started by fngolfer, Oct 22, 2014.
  1. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    Why does this hose keep backing out a little even though I've cleaned inside and tightend the band clamp as much as possible?
  2. Metalman
    Are the mating surfaces oily before you clean them?
  3. bmwh0r3
    bmwh0r3 Member
    Sep 17, 2014
    41
    20
    Do you have an intake? My experience was with getting everything positioned properly
  4. DneprDave
    Clean both surfaces and spray them with hairspray before reassembling. The hairspray will dry and keep things stuck together, but you'll still be able to take it apart if you want.
  5. fngolfer
    Apr 1, 2012
    100
    46
    Los Angeles
    Yes it was a little oily. I thought the catchcan would do a better job. Great idea using hairspray. Gonna try it now.
  6. Metalman
    Not sure which year you have.... some of the engines have a dual track PCV system.... One line goes directly to the intake manifold.... A secondary line merges just before the turbo cold side..... If your OCC is on the direct line to the intake it won't do anything for the secondary line going to the turbo....
  7. fngolfer
    Apr 1, 2012
    100
    46
    Los Angeles
    2009 N14. The BSH catch can is connected to the cold side of turbo and the back PCV is plugged. I cleaned everything up, used a little hairspray and drove it hard just now and all is good. I did notice that the clamp was getting a bit deformed so I straightened it out before I reinstalled it.
  8. Terminal Velocity
    Dec 2, 2011
    62
    14
    It might back out a bit but it won't come off. Every MINI I've had has done this.
  9. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    ive used red hot blue glue to keep them on...
