2nd Gen R56 Cooper S Turning it to JCW or GP2
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Nov 8, 2015.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    I have stock 2008 R56S and i want to modify its suspension/tires (and what ever else is needed) in order so that it looks, brakes and handles (not talking about the power) like either a JCW or a GP2. What do i need?
    Do you caire about ride quality?
    I have Eibach pro springs, Koni yellows, IE camber plates (but I would order Collen Greens plates if I could, there's a thread on them) and Helix adjustable rear control arms. I just need a good rear sway bar.
    A fat wallet and lots of parts from MINI.
    You can go on RealOEM, use your VIN to see the part numbers for your current suspension, then compare them to the ones on the GP2. Order all the ones you don't have and install.
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    The JCW and GP2 are a little different. The GP2 has coilovers and very sticky tires.
    To match the JCW you need: Lowering springs, matched shocks (I would suggest adjustable), and adj rear sway bar.
    To match the GP2 you need: Coilovers and adj rear sway bar. For coilovers, I would suggest Bilstien PSS10 or AST 5100 because both have adjusters on the bottom.
    For both: light wheels and sticky tires.
    In addition, I would suggest: adj rear control arms and adj front camber plates.
  5. Metalman
    It's genik....
    It'l never happen...
  6. Eric_Link
    Eric_Link New Member
    Sep 28, 2015
    46
    20
  7. Eric_Link
    Sep 28, 2015
    46
    20
  8. Firebro17
    ^^ That's a very nice look'n MINI. My second favorite colour combo.
  9. genik
    genik Member
    Feb 20, 2012
    402
    19
    #9 genik, Nov 14, 2015
    Εtic_Link your setup i call perfect!!! Great looks mate, just right! Any pics from the rear view?
    Can you please state what changes you have done for achieving these looks on your mini?
  10. Eric_Link
    Sep 28, 2015
    46
    20
    Thanks guys. I just updated my garage with a bunch of pics and everything that's been done to the MINI. Just a couple of mods left to go... ha right...
    My Garage
    The MINI Challenge sound clip is pretty good. It's really mellowed over time and is working out great.
