Urgent: 05 mini s putting megan coils on
Discussion in 'Starting Line - New Member Introductions' started by jeanniemp, Mar 9, 2014.
  1. jeanniemp
    jeanniemp New Member
    Mar 9, 2014
    9
    New here and installing megan racing coilocers on today when I got to rear and cannot figure out how to get to the top of where the rear strut goes through the body of the car. If there is a DIY for these please let me know.
  2. Motoring Magic
    Motoring Magic New Member
    397
    266
    Thousand Oaks, Vta cty, socal
    #2 Motoring Magic, Mar 9, 2014
    You are thinking wrong-you must remove the entire assembly with the two 13 mm head bolts facing downwards (towards the ground) then assemble the top "hat" or mounting parts to your coilovers. assembly is the reverse of disassembly-you cannot access the top nut while assembly is on car
  3. Jason Montague
    :cornut: 1st post! Welcome to MA.:Thumbsup:
  4. Dave.0
    Do this ^^^^ you cannot access the top of the rear shock from inside or outside the car until you remove them by taking out the two 13 mm mentioned above. :Thumbsup:
    Welcome to M/A. :Thumbsup:
  5. jeanniemp
    Mar 9, 2014
    9
    Okay thanks a lot I had to hault on the install. The bolt on the bottom front strut just broke so I have to get it drilled today... already tried myself and the drillbit is in there now :'(
