Interior 1st Gen Valet Key Unlocking / Locking
Discussion in 'Tuning and Performance' started by jerseymini, Dec 7, 2012.
  1. jerseymini
    jerseymini New Member
    Aug 10, 2012
    27
    10
    Hey,
    Does anyone have this issue? I got a valet key from the dealer, and now when I use it to drive with, the lock continues to lock/unlock , until I get
    to appx. 40mph... Its very annoying .
    The dealer said that the valet keys do that... sounds weird to me..
    Got the valet key, so I can get a remote start installed, now I am not so sure to use this key, if the locks will continue to lock / unlock...
    Thanks
    jerseymini
  2. Mr. Jim
    I think it's meant to do that as its only for valet, not to be used all the time.
    That's my story and I'm sticking to it....
  3. Dave.0
    I do remember something like this with older Hondas when I was installing alarms and remote starters. You can use a valet key for the remote start since the car will only be "running" and not moving.
    When you remote start your car it only needs the chip in the key to be near the cars ignition to override the OEM immobilizer system. You should not drive with that key as it for valet use as you have found out.
    They lock and un-lock so the $3.00 an hr. valet that works for tips does not lock your keys in your car.
    Just so you know when you open you car with the non-valet key and put it in the ignition and turn it to the "on" position will override the valet key and its limited functions. If its like most remote starter system the car will shut off if you hit the brake and try and put the car in drive without "A real" key in the ignition and turned to the "on" position.
    Good luck with your install and let us know how everything works our.
  4. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    I really hate bringing dead threads back to life.
    But I am wondering if there is any more info on this.
    I cannot lock the doors when driving the car, using the non remote key, or the valet key.
