Valve Gasket and Engine Light issue
Discussion in 'Starting Line - New Member Introductions' started by haumea, May 22, 2014.
  1. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Hello, I'm new to this site. I have a 2009 Mini S for the past 2 years. Been problem free. A couple months ago during a maintenance check up we were told the valve housing has a leak, no noticeable leak the hoses, do leaking of oil noticeable. The engine came on, on Monday flashed once and held steady. The car started very rough and of course I was leary of driving it and called the dealer. Dealership has indicated that there is carbon build-up on the valves. They have replaced the gasket which was covered under the Hendricks Extended Warranty. Now they are recommending to blast the carbon on the valves as this should be the solution. Service manager is indicating the this is common for the Mini S. Has anyone had this issue with carbon build-up? We use Shell or Chevron in car although I am second 2 owner from same dealership. I am concerned with comment of this is common. This is a not a cheap common issues it's over $900.00 Can anyone shed light on this if you have had the issue? I did not see the code, nor did I know where to look for the code. I almost want to trade this car in.
  2. jcauseyfd
    jcauseyfd New Member
    May 25, 2009
    201
    31
    Graham, NC
    Carbon build up is inevitable on the direct injected engine found in MINIs (and other manufacturers) because no fuel is washing over the back of the valves. You should probably consider this a maintenance item and plan to have it done on a regular basis like 50 - 70l miles. An independent shop can do it for much less. Luxury Auto in Raleigh charges somewhere between $350 and $400.
  3. MCS02
    6,322
    Welcome to MA! Sorry to hear about your trouble, but jcauseyfd is correct.
  4. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Thank you for the update. Unfortunately that blasting part is quite costly here in California at the dealership. I just thought it was rather soon for this, subsequent to that it's not covered of course by the extended. We gave them the go ahead to blast, I hope that solves the issue. Thanks for the tip.
  5. Dave.0
    Welcome to M/A the FUN Mini site. :Thumbsup:
  6. Nathan
  7. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    Welcome to the coolest MINI forum on the net.........:cool:
    Shop around on the carbon blasting.....See if your local delaer can help you out on the price....It's worth a shot to ask again ...and again...untill they help you out.
  8. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Hello everyone,
    Carbon blasting is done and car was driving good, this was 2 weeks ago when I posted originally.
    I also addressed a leak which my girl had to get towed in again to fix the oil housing gasket and a leak in the oil line to turbo something? This was covered.
    I have had the car back 48 hours now, yesterday I had my hubby drive it to work as he works 67 miles from home. He said car drove great. He came home parked the car,locked our gate and noticed no power to the car no lights etc., car would not start so he had to pull out the key while the fob stayed stuck. So am I assuming here that it's the battery??????? I woke up just now went outside there was enough juice to open the car, it tried to start but died out, there was no light indicators. am I missing something here?
  9. MCS02
    6,322
    Yep sounds like a bad battery. MINIs can do very odd stuff when the battery goes bad.
  10. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Thank you. It's my luck Friday the 13th. Especially it's been in and out of the shop in 3 weeks. Again, luckily the other issues were covered except the carbon blasting but crap. I have a long distance drive from NoCal to San Diego in 45 days and Augh I'm getting leary. What is the normal time frame for change of battery on a mini anyway? It's an 09 and it's the original battery
  11. ZippyNH
    Most stock batteries last 3 or 4 years....so sounds like you are due!!
    Battery should be tested to ensure it is the problem...but testing is usually free....
    Used cars can be interesting....
  12. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Okay need some advise, our mini took the jump it started and it didn't power off like last night. Hubs turned car off, waited 30 minutes went to start mini did start. My concern is he drove home 67 miles from work and then powers off??? So it appears not the battery?
  13. MCS02
    6,322
    No it can still be the battery get it checked. Also make sure all battery connections are clean and tight. Make sure that the positive battery cable bolt under the hood it tight, this is a known problem spot. MINIs can do some very wears stuff when a battery is going bad. Pluse if you jumped it and let it run for a few minuets you just put a service charge on it. If the battery has a bad cell it will not hold a charg and will not recover correctly after a load is put on it. This is why you still need to have the battery checked. Most part stors do it for free.
  14. DneprDave
    The only way to know for sure is to have the battery tested. Take it anywhere they sell batteries and have them test it.
    Dave
  15. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    What recommendations of a good battery do you folks recommend? Please advise. Husband wants recommendations on long wear battery. Thanks.
  16. ZippyNH
    Hard to buy a "bad" battery these days....
    Batteries like optima "red top" , orbital, and several "premium" battries have a different connstruction...tend to last longer than a flooded cell type.
  17. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Thank you all. So as I sit here car less today :( Was hoping to drive down to the beach today. Oh well
  18. ZippyNH
    Go have a battery put in (if it needs it)....so simple.. ..an off the shelf part!!
    It is crappy and drizzlely gloomy up here....lol..wish it was sunny!!
  19. haumea
    haumea New Member
    May 22, 2014
    17
    Northern California
    Hello everyone, sorry I'm so new to Mini well we got her a few years ago and it was the same dealer that had an original leaser on it and felt comfortable she's a good car. Just these past 3 weeks was more than I bargained for. $$$
    So it was the battery, unknown to me as I have never looked under the hood although it does go in for service......there is an indicator light and it was black. So the question remains would at service spot check the battery to advise? I mean I have an AudiA3 and a Toyota Tundra and we are always well informed of battery use.
  20. MCS02
    6,322
    I'm not sure what the question is. But if you mean should the service department have checked battery, the answer is no. Usually it is only checked if their is a problem.
    I'm glad the battery got you going agin. Just keep the date you bought the battery and when the service time is up it will be time for another battery.
