Vehicle Tool Kit - 10 Clubman S
Discussion in 'MINI' started by apexslide, Oct 3, 2010.
  1. apexslide
    apexslide New Member
    Sep 24, 2010
    13
    Waiting to hit the PowerBAll
    Racing Capital of the World
    Just got into the boot of my new 2010 Clubman S and have a question.
    What should be in the vehicle took kit in the boot. Looking at the manual there appear to be 2 setups. You can have the "vehicle tool kit and tire change" set or the "tire change set for space-saver spare tire."
    I have RSC tires and was told by the dealership there wouldn't be a spare tire because I had the runflats. I was also told there would be a tool kit in the back that had everything I needed plus hazard triangles.
    I have had the car for a week and this is the first time I got all up in the boot and looked at the tools. I found a jack with wheel stud wrench, flat and philips screwdriver, towing eyelet, hub cover remover. There are other open bins in the cargo tray. It looks like it was molded for the compressor and sealant bottle but they are empty. I also do not see a valve removal tool. Those should be standard shouldn't they?
    Cheers!
  2. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    We dont get the compressor, sealant, triangle, and emergency kit in the US. What you have sounds about right. Mine was delivered w/o anything but a tow hook in the foam thing. They sent a new kit to my house later on, as I guess quite a fe 09s got skipped.
  3. Justa Jim
    Can the compressor and sealant be ordered from someplace? Might be nice to have. I had to get the first aid kit and triangle from a company in the UK.
    Not sure if it is exact fit but you can get those easily from an Autozone or Pep Boys.
  5. Justa Jim
    Just did some checking and Out Motoring sells one as well as Minamaina, but they don't look to fit in the tool kit in the boot.
  6. Metalman
    If you check realoem, they list their "Mobility Kit" that comes in a traveling case that includes a compressor and a container of sealant for something like $150.00 or so.:eek6:
    They also list the compressor and sealant separate for something like $130.00 or so. There is also a special tray part number listed as the "Mobility Tray", probably to hold the compressor and sealant as well as some of the other emergency tools. The handy thing about going the tray route is it will nest nicely in the boot well created for the tools. I guess you pay the price for the convenience, in a tightly packed small car. For what its worth.
  7. CHKMINI
    The one from Aaron at Outmotoring contains the compressor and all the other stuff and it too is $150.
  8. Justa Jim
    Thanks Chuck.
  9. apexslide
    Sep 24, 2010
    13
    Great work guys, I appreciate it but I'm confused why we don't get them in the US?
  10. Metalman
    On the compressor and sealant, they are available in the US as an option called the "mobility kit", you just have to pay extra for it. As for why it's not included, marketing maybe?
    The Justa has a spare tire, so it's assumed it may not be needed. The non-Justa's come with run-flat tires (or tyres), so it's assumed it may not be needed.
    The warning triangle that Jim alluded to is not a DOT requirement in the US, even though there is an indent for it in the boot panel. It is a requirement in Canada, so the Canadian MINI's have the triangle. Like Jim, I didn't like the dent not being filled with a MINI part, so I just ordered mine from the MINI dealer up in Toronto along with the MINI first aid kit. I'm thinking about the compressor.:D
    Since the Justa has a spare tire, the tool kit also includes the wheel chock that happens to be a delete on the non-Justa's, so it's related to content.
  11. Justa Jim
    Having done several tours in Europe, were we were required to buy a first aid kit and triangle for the cars we shipped over, I liked the idea of having them. Like Chuck, since the spots to have them were there, I ordered from NewMiniStuff in the UK.
