Exterior 1st Gen Vented Hood and AIT
Discussion in 'Tuning and Performance' started by Helix Wildebeest, Jul 5, 2012.
  1. Helix Wildebeest
    Helix Wildebeest New Member
    Feb 29, 2012
    33
    54
    I noticed that my Intake Air Temps (AIT) were really getting high with the stock intercooler and this hot weather. I was seeing a peak IAT of over 60*F above ambient. I had to get the hot air out. The cure: A pair of stainless steel bildge vents, a cutoff wheel, and black plastidip. In my eyes, the design matches the rat rod styling of the Wildebeest. The result quicker intercooler recovery, longer time before soak, and an average of 25*F lower AIT.
  2. Johngo
    Johngo New Member
    1,671
    200
    Art Director
    Sugar Hill, GA
    Cool... :Thumbsup:
  3. BlimeyCabrio
    I know this was for function and not looks. And you report it functions well, which is excellent. That said...there's only a handful of MINIs that look would work with. And that's one of them.
    I like it :Thumbsup:
    Please... PLEASE... don't everyone go out and copy this. Odds are it will look like CRAP on your car. :lol:
  4. Dave.0
    Ok I like the hood, vents thay are cool.
    I did notice something else. The wheels arches are held on with bolts which look cool. How did you guys do that?
    I zoomed in 400 % and I can see that you put nuts on the studs.
    How did you make the little cups in the arch that hold the nut to the stud?
  5. Justa Jim
    No, No, No, Monica. I know they do look a lot like Dragon Scales, but.......... :D
  6. Helix Wildebeest
    Feb 29, 2012
    33
    54
    Ha! Most of those studs are cut off. The wheel arches have about 1" cut off and the rest is bent upwards to clear the tires. I screws and glued the arches to the car body. Remember I paid cash for the car and don't care a bit about maintaining resell value.
  7. Dave.0
    Well it looks great. I even like the "Gold" wheels on the beast.
  8. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Man that is one sweet MINI! +1 to what BlimeyCabrio said I have seen 2 MINI's that look good with hood vents, this one and the louvers on Nathan's...
  9. TheModFather
    #9 TheModFather, Jul 5, 2012
    All of my hood vents work great aswell!:Thumbsup:
  10. TheModFather
    Thanks for fixin that Nathan.
  11. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    #11 BRG_Paul, Jul 5, 2012
    Very cool! (no pun intended :) ). Actual louvers cut into the bonnet might be an interesting mod. I live in York, PA- the annual location of the East Coast Street Rod Nationals .. At the show there are loads of shops who cut and form louvers in the hoods of the "rats". ImageUploadedByTapatalk1341530508.639395.jpg
    OK this might be a bit much but you get the idea.
  12. Justa Jim
    I'm close to you, down near Gettysburg. Get to York from time to time.
  13. Metalman
    bahawton.... if you do add vents, the abs is much more sensitive to thermal expansion/ contraction than say a vent made from a metal. A metal vent will have similar coe as your stock MINI bonnet. You won't get the unsightly buckling gaps between the fasteners if you stay with steel....
  14. Dave.0
  15. bahawton
    bahawton Member
    Feb 18, 2011
    Thanks Metalman- That's great info!
  16. ScottinBend
  17. bahawton
    bahawton Member
    Feb 18, 2011
  18. BRG_Paul
    Nov 20, 2011
    758
    184
    York, PA
    I was in Waynesboro today...probably fairly close to you.
    I actually like the idea of louvers on the bonnet if they aren't too excessive. Certainly would help to keep the AIT a bit cooler.
  19. Dave.0
    Just think how cold you motor could be with hood vents and a Meth kit.
    Hummmmm...
