Engine Drivetrain 1st Gen Cooper S Vibra-Technics Torque Link install
Discussion in 'Tuning and Performance' started by M^Cubed, Feb 20, 2014.
  1. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    For anyone who has installed the Vibra-Technics lower mount for 05-06 MCS - did it require any modifications?
    I removed my BSH mount this evening and found out that the bolt does not fit through the Vibra-Technics mount on the large (aft) side.
    I initially tried using the bolt to thread into it, but it got stuck just past half way. It definitely needs to be bored out for the bolt to fit properly. The fore side fits fine, but the overall width of it is a little narrow and has some wiggle room in the bracket. I'm not sure how I feel about that.
    Its so easy you should not really need any instructions.
    2 bolt out remove BSH, replace with VT put 2 bolts back in and tighten.
    Crack open an beer and enjoy a job well done. :Thumbsup::beer
  3. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Well obviously I did not have an issue with the lack of instructions. I did not ask for instructions. I asked about the requirement of modifying the part to fit properly.
    The link has issues on both ends. It is too narrow on the fore side and the OE hardware does not pass through on the aft side.
  4. minime331
    minime331 New Member
    Jan 27, 2012
    145
    30
    washington dc metro area
    Try heating it up
  5. Dave.0
    Well mine fit fine and snug and I had no issues using the OEM bolts. No modifications needed and I also removed the BSH mount also.
  6. Mr. Jim
    Colin said the one hole needs to be a little larger. I just used a drill bit in a press to enlarge it just enough to fit.
  7. Dave.0
    I must have got one of the very early one's because mine went right in very snug. :eek:
  8. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Thank you Mr. Jim
  9. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    If you got the part from me, I am sorry I generally check all of them before I send them out, however sometimes escapes happen.
    Normally if they are too small i ream them out or use a drill press to slightly open the hole.
