2nd Gen R56 Cooper S Walnut blasting.....anyone have it done?
Discussion in '2nd Generation: 2007+ R55 through R61' started by jiminni, Dec 5, 2012.
  1. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Has anyone had it done at the dealer? Is this something they will do under warranty? We have 6 months of warranty left on the wifes 09 MCS, and may end up selling it, or maybe get an extended warranty and keep it? Just don't know at this point. But I'm sure the valves will need to be cleaned either way. So has anyone got this done under warranty yet?
    I think some folks have had that covered under warranty. I'm not sure if it was due to some check engine light problem or not. It sure is worth taking it in & telling them you are having diminished performance from your MINI.
  3. Savvy
    had it done on my '09 MCS at ~78k... enjoyed the bump in performance... then traded it in (at 80k) on a cherry R53 Checkmate w/ less than 11k. But I paid out of pocket to have it done.
  4. Minidave
    4,591
    My '09 needs it done (I pulled the intake manifold back and looked for myself) but my dealer (who will do anything they can for their customers) said they couldn't get MINI to pay for it unless the car threw a code - and mine hasn't. I've got 3 months and 5K of miles left to have it done under warranty......that's why I'm building my own walnut blaster set-up. I figure it will be an every 30K maintenance item for me.
  5. jiminni
    262
    Ca.
    Yea, I thought about that, just tell them it is not running the same anymore, how would they know?
  6. jiminni
    262
    Ca.
    At the dealer? How much did it cost you?
  7. jiminni
    262
    Ca.
    Good info, thanks! Thinking that my mechanic, Steve from Custom Mini Shop could use such a machine. R56's are starting to become his main source of income :arf:
  8. Savvy
    Mine cost me under $300... the benefit of being the "guinea pig" for a regional "performance" shop.
  9. ljmattox
    ljmattox Active Member
    Dec 28, 2011
    223
    123
    IT consultant
    St Louis metro USA
    Indeed, but that probably cuts both ways? Dealer: "Really? Why do you say that? No codes, idles & runs smoothly." Or something. That'd be my luck, I'm sure.
    I wonder if this procedure will ever make it to the service schedule?
    (from a guy who's old enough to remember ancient two-stroke motorcycles that required the head to be "de-coked" every x,xxx miles, "back in the day")
  10. e46tor56
    e46tor56 New Member
    Nov 3, 2012
    357
    BMW/MINI Parts Advisor
    I'm out of warranty with 65K and I'm looking for a indie shop in my area to do this for me.
  11. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    I had it done by my local dealer about 10k miles ago. Cost $450'ish. Annoying? Yes. Worth it? Hell yes. Noticeable improvement in gas mileage and throttle response. Plus improved longevity to the engine.
  12. Rockridge
    Rockridge Member
    Oct 12, 2009
    32
    Director of Software Development
    I had it done at the Mini Dealer in Warwick. My car is a 2007 MCS with AccessPort and a number breathing mods + Oil Catch Can. The car only has 27,000 miles. The Tech brought me into the service bay, and I was able to view the back of the Valves and such to see that there was significant buildup. I did not get an "after" look, but that's my fault. i should have asked. The work that was done, was the following:
    Walnut Blast and Vac
    Seafoam like cleaning of intake systems
    Loading of new ECU code
    It cost me about $500
  13. beam
    beam New Member
    Aug 25, 2011
    16
    I've had it done to my '10 R56.
    Carbon build-up was pretty bad, so the dealer did this for me.
    Completely covered under warranty!
    Seems to have done the trick, for now ;)
  14. Metalman
    Hey... It's just a maintenance detail...:rolleyes5:
    Kinda like putting new brake pads on or changing the oil, or, or, or.......
    Use'ta be you had to hand crank the engine to start it...
    Then they added a starter and battery...
    Now they sell more batteries...
    :idea: Think I should invest in Walnut futures. :D
  16. Minidave
    4,591
    You may be on to something there....when I dropped by my dealer's the other day to look at their spray nozzle on their walnut blaster, they had a large pallet of 100 lb bags of walnut shells cross stacked 4 on a level up almost to the ceiling! They seem to think they'll be doing a few of these, is my guess.
    My S/A says they charge about $400 to do the actual cleaning, but they usually also reflash the computer and do some other maint at the same time so that the average ticket is more like $750 - I guess that's where I got that price....
  17. Crashton
    It is good to know that the dealers are aware of the special maintenance requirement for those DI engines. I'm sure other makers are having to do the same thing on their DI engines.
  18. Savvy
    The one thing about those bags of shells... if they aren't smart about it... they can easily tear through 3 or 4 of those bags per car
  19. Metalman
    Now the big question....
    Do the bags of walnut shells have a BMW part number assigned.... Are they certified BMW...
  20. MotoringLJ
    MotoringLJ New Member
    Dec 5, 2012
    I took mine into the dealer on 10/8/10. She had the check engine light on and was throwing a code (I'm not sure which). She was at about 36k miles. This was covered under the 3 year maintenance plan.
    I just had this same problem a few weeks ago at about 62k miles. She was missing on all 4 cylinders. The dealer charged right around $800.
