2nd Gen R56 Cooper S Water leak
Discussion in '2nd Generation: 2007+ R55 through R61' started by fngolfer, Feb 29, 2016.
  1. fngolfer
    fngolfer Active Member
    Apr 1, 2012
    100
    46
    Los Angeles
    So I change the oil yesterday and started my R56S this morning and saw clear looking water dripping from left front of car. Gotta be the expansion tank right? No time to inspect and took the wife's car. What is the likely or common culprit?
    Possibly the seal at the bottom of the tank. I have been told that moving the tank out of the way for the filter change can cause that.
  3. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    My R56 CoopS has leaked water from multiple places over the years -- often at the left front. The expansion tank would be the easiest leak to find, and fix. Let's hope it's that.
    CD
  4. nkfry
    nkfry New Member
    Roseville, MI
    Most likely as Crashton said, a leak from the feed line on the expansion tank when you did the oil change. They have since revised the part to keep from having that leak occur.
    MINI Expansion Tank Hose
    You may want to take a look at your thermostat and oil filter housing area for safety sake, either of those can leak in the same area. Chances are that your leak was caused by moving the expansion tank though.
    Nice to know that part has been improved.
