We Have 400cc Injectors for the R53 MINI
Discussion in 'Engine & Drivetrain' started by M7 Speed, Jun 4, 2013.
  1. M7 Speed
    M7 Speed Banned
    May 14, 2013
    WE HAVE 400cc INJECTORS FOR MINI COOPERS.
    Get the most power out of you modified MINI Cooper with a set of our injectors. You're leaving horse power on the table without them!
    400cc: M7: MINI Cooper Performance Parts
  2. ZippyNH
    $100 core charge EACH?!
  3. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    TUNE REQUIRED should be mentioned.
  4. M7 Speed
    M7 Speed Banned
    May 14, 2013
    Yes Zippy, the core charge is $100 each. Keep in mind that you do not pay that if you ship in your cores. It's the only way we can get someone to return the cores. Hope you understand :)
  5. M7 Speed
    M7 Speed Banned
    May 14, 2013
    Good point AliceCooper!
  6. TheModFather
    So its safe to say, since there is a core charge "or you send back your currant OE injectors" that these are just drilled out OE injectors that will provide a higher flow rate?
  7. cct1
    How does redrllling give the same atomization as stock? Has that actually been tested? There are so many good injectors, available at a reasonable price without a core charge, what exactly is the advantage of these redrilled injectors?
  8. TheModFather
    Nope.... A drilled injector will never spray as good as an injector that was made (From the FACTORY) to flow the same amount of fuel. 99% of the time the spray angles are way off, and just spraying the intake ports down with fuel.
    There are plenty of better options than redrills... 440cc 550cc 1000cc... Take your pick pretty much ALL of them are cheaper than your "CORE" fees here! All of them will require a tune, but so do redrills of the same flow rate. Why anybody would want to pay double for a drilled injector over a quality set of injectors, plus be able to keep or sell your OE injectors... Well that just sounds stupid to me. ;)
  9. KittyMini
    KittyMini Club Coordinator
    1,183
    Um sorry, but I would not buy injectors with a "core charge" if my life depended on it.
  10. swimbaxter
    swimbaxter New Member
    Jul 6, 2012
    11
    Drill baby drill. This seems like a very poor value prop for the consumer.
  11. Dave.0
    #11 Dave.0, Jun 11, 2013
    400's are way to small to make any real power. Plus being re-drills with a $100 core charge......:lol::incazzato::lol:
  12. Mr. Jim
  13. Dave.0
    What's up Jim? Are you and all those guys all coming over for a beer....:beer
  14. TheModFather
    Somebody say BEER?
    Mmm... Beer. :)
  15. Mr. Jim
    Beer n a BBQ!
  16. TheModFather
