2nd Gen JCW Welp.... I finished making my custom upper strut brace...
Discussion in '2nd Generation: 2007+ R55 through R61' started by Metalman, Jul 14, 2011.
  1. Metalman
    Well almost.... Structurally it's a trapezoid... better but not the best. I still plan to add a diagonal which will greatly solidify the design. I used the same attachment points as the rear adjustable seat back locks.
    The toughest part was cutting through the plastic body claddings for the two brackets. Took my time and didn't mess up the covers.
    Anyway here are some pics....
    My bracket is sandwiched behind the seat back bracket and held on using the same OEM bolts.
    Here is a close-up of the heim joint connected to the bracket.
    Here is the right side mounting.
    And here is the left side mounting.
    Viewed with the hatch open.
  2. Jason Montague
    :cornut:It looks functional to me but it looks essentially the same as the after market one that I put in my car. Where are the other 3 sides of the trapezoid?Or are the other 3 sides the car structure itself? Just curious. I'm a little slow and have probably missed some thing.:Thumbsup:
  3. Metalman
    Yep, body structure is basically a big "U". Now with my upper bar, I've boxed it in as a four sided structure. With the addition of a diagonal (need to make this), the structure won't be able to move.... :D
    Nice work Chuck. :Thumbsup:
  5. Jason Montague
    :cornut: Thanks, I got it.:Thumbsup:
  6. old81
    1,542
    Kinda like the bar in a GP but in the back? Looking for a rigid body?
    When are you going to track your MINI. :) Nice work. :) :)
  7. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
    Thing of beauty :Thumbsup:
    Nicely done Chuck
  8. Justa Jim
    Very nice indeed. :Thumbsup:
  9. grodenglaive
    grodenglaive New Member
    Apr 3, 2010
    313
    68
    Ottawa, Ontario
    cool. It always amazes me when people can make their own parts.
  10. Mr. Jim
    Sweet job MM!
  11. Justa Jim
    I noticed you still use your boot cover/shelf, so as my wife asked me once, "Why do you what a mod that nobody can see"? :D
  12. ScottinBend
    Is this actually attached to the rear strut towers?
  13. Nathan
    The bar in the GP is not structural. It is there due to UK laws and 2 seat cars. It's sole purpose is to block items from shifting forward and getting into the passenger area. MINI calls the part a "Cargo Rod" in the parts listings. It is only held in place with 6 Fillister head self-tapping screws, ST4,2X13MM, 3 per side.
  14. Metalman
    #14 Metalman, Jul 15, 2011
    No.....
    The tops of the rear struts are at about the same height as the boot floor (actually the upper boxed framing perimeter). The seat back lock mounts are at a much higher point unfortunately. The tops of the rear struts sit pretty low in relation to the wheel well and body.
    My plans for the diagonal members are to make the connection to the strut tops.
  15. Justa Jim
    MM, do you really notice that much body movement to feel the need for this? I'm not sure I have seen this offered by a vendor and I figured they would if it was a problem. Just asking for my own information.
  16. Metalman
    Can't answer the second question. Haven't changed any of my suspension components. I would assume with a complete change out to poly bushings over the OEM mushy rubber units it might be easier to tell if there is flexing going in back there. Someone like Redbeard or others that spend a lot of time on the track could better answer that question.
    Several aftermarket companies sell a rear brace, M7 has one and I think OMP makes one, Mini Mania has one, Racing Dynamics is another. Don't know how effective those are.
  17. OldBlue
    OldBlue New Member
    Sep 7, 2010
    115
    11
    Die Shop Coordinator
    Cleveburb, OH
    I like it!
  18. Jason Montague
    :cornut:Me Too.:Thumbsup:
  19. Jason Montague
    :cornut: (for me) I'm more interested in some thing that functionally works than I am in eye candy.:Thumbsup:
  20. Metalman
    I'm still trying to figure out where the straight bar attaches. I'm assuming it's a rear under-strut bar???
    Here is a pic of the front bar attached....
