2nd Gen R56 Cooper S What did I do?
Discussion in '2nd Generation: 2007+ R55 through R61' started by itsmewutup, Dec 18, 2013.
  1. itsmewutup
    itsmewutup New Member
    Apr 11, 2012
    351
    67
    Time to pick y'all's brains a bit. As I was driving to town earlier I dropped from 6th to 4th to pass a slow driver. When I stepped on it, it seemed to bog down. Now I have to be extremely easy on the gas or else it will bog down again. What did I do to it? I had this issue last year but it was a different motor. And I don't remember what the cause was. I know I never did get my fuel pump replaced but some had said that's what was wrong. Since getting the new motor put in I've not had any problem until now.
    08 MCS
  2. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    I haven't a clue but will bump it up for the experts.....
  3. mrntd
    Seems like a fuel problem. Filter or injectors dirty. Pump bad.
    When you push the peddle your getting more air but not the fuel and it bogs. In the carb days it was filter and fuel jets getting dirty.
  4. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    I'm not a gen 2 person but have a question, do you think this problem before had anything to do with you having to replace your motor?
    The reason I ask is knowing the gen 1 fuel systems, if the vacuum line to the fuel regulator comes off, it causes a lean out situation, the motors won't bog, but that could simply be the difference in how a turbo car reacts to the problem vs an S/C car.
    Just a thought since it does sound fuel related, but like I mentioned, I'm not up on my gen 2 fuel systems.
  5. itsmewutup
    Apr 11, 2012
    351
    67
    I'm honestly not sure if it had anything to do with it. I hope to help it didn't. I don't even have this moor paid off yet lol. I'm off for the holidays for 2 weeks so I'm gonna mess around with it and bring it to my shop that installed the motor and see what they have to say about it.
  6. Zapski
    Is it a delay between stepping on the gas and getting power? If that's what you mean, it could be a clutch or flywheel that's going. I had mine done last year on my 08 MCS.
    This year it's just been leaks of various kinds.
  7. itsmewutup
    Apr 11, 2012
    351
    67
    No, that's not it. Just replaced my clutch in February. Basically if I step on the gas slowly it'll be just fine, but if I mash the gas to the floor or even push it too quickly it'll bog down (like its not getting fuel) I've been told its a good chance its got carbon build up. Its gotta be either that or something with the fuel. Probably get it cleaned first since it most likely needs to be done anyway then go from there.
  9. itsmewutup
    Apr 11, 2012
    351
    67
    Didn't think of that. Where would I go in at?
  10. Miniman007
    Miniman007 New Member
    Dec 16, 2013
    this is purely a guess but I'd say take off intake manifold and go in that way.
  11. Metalman
    Pull a spark plug first, take a look around. See if the cylinder walls and tops of the pistons look like they have carbon deposits.
  13. itsmewutup
    Apr 11, 2012
    351
    67
    Stopped by my local shop today. Turns out its a bad Coil. Trying to decide to go with OEM $53 cheapest I've found or Facet $33. I will be replacing all 4 of them so that saves me $80. Recommendations? Yes? No?
  14. Dave.0
    OEM because MINI's can be finicky about some aftermarket parts like coils. I would also replace all of them, but then again I am OCD about my car.
  15. itsmewutup
    Apr 11, 2012
    351
    67
    As am I :)
    I'll just keep my others for spares.
