What's the technical name for the housing that secures
Discussion in 'MINI' started by bcgreen, Jan 15, 2017.
  1. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    the fog lights. I cracked mine and now the fog light just holds on by the electrical cord.
  2. Savvy
    Fog light housing. For what gen?
  3. Firebro17
    Here's your sign.
  4. 00Mini
    2,227
    Thingamajig :devil:
  5. MCS02
    No it's not it's a thankambob.
  6. MCS02
    We like to help at MA!
  7. Metalman
    MINI makes lots of MINI's.... Some small and some huge...
    Which MINI do you have?
    MINI tends to put the fog lights in the bumper low to the ground for..... you know..... the fog....
    They also make an optional light that is mounted up higher on the bumper in front of the grill.... More of a driving light than a fog light...
    Which would be this one...
    In the case of the R56.... It could be this one...
    In the case of the R53.... It could be this one...
    Are you asking about the fog lights or the auxiliary driving lights?
  8. Minidave
    4,594
    Isn't that the doohickey?
  9. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    This is a 2004 Mini Cooper S.
  10. bcgreen
    bcgreen Member
    Jan 12, 2017
    41
    10
    The fog lights are held onto the vehicle by attaching to something. The horns are also attached to this unit as well.
    This is for a 2004 Mini Cooper S.
  11. DneprDave
    You have been a little miserly with the information, about your car, needed to answer your question.
    You could find the name of what you want right here, just drill down, answering the question about your particular car and you'll find it.
    http://www.realoem.com/bmw/select.do?
  12. Savvy
    #12 Savvy, Jan 16, 2017
    See next post........
  13. Savvy
    More than likely the prastic ears on the fog light itself have broken. Happened to one of mine. Darned squirrel! Bought a used fog super cheap & installed it. Loosen the prastic inner fender liner & you can get at it. Easy peasy....
  15. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
  16. drabdub
    drabdub Well-Known Member
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    are you looking for the foglight housing or the piece behind the bumper that it mounts to?
