Brakes Wheels 2nd Gen Tires Wheel help?
Discussion in '2nd Generation: 2007+ R55 through R61' started by rum4, Apr 26, 2012.
  1. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Can someone tell me the correct torque for the lug nuts on a 2012 Clubman? I think it is 88 ft lbs, but not sure.
  2. goaljnky
    3,105
    394
    Should be 88.5.
  3. rum4
    4,568
    1,475
    SC
  4. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Incorrect. 103 ft/lbs is the correct torque for the M14x1.25 lug bolt.
  5. rum4
    4,568
    1,475
    SC
    Damn got to tighten them more tomorrow.....Do I need to jack it back up to tighten them to 103? I tightened them to 88 which I found somewhere but not sure where!?
  6. goaljnky
    3,105
    394
    My bad. Completely brainfarted on the different models. Any idea why the difference from the R53 M12 bolts?
  7. DneprDave
    The Series 1 MINIs have M12 lug bolts, so they are torqued to 88 ft-lbs rather than the Series 2's larger M14 lug bolts which are torqued to 103 ft-bs.
    Dave
  8. rum4
    4,568
    1,475
    SC
    Maybe we should make a sticky with this info so it is readily avaliable for everyone. Thanks for the info everyone.
  9. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    No, you can do it on the ground.
  10. Redbeard
    1,636
    398
    Math in link below:
    Thread pitch and torque mathmatics
  11. goaljnky
    3,105
    394
    Yes, that explains it. :frown2: :lol:
