2nd Gen JCW Where Is My Oil Filter?
Discussion in '2nd Generation: 2007+ R55 through R61' started by Only John, Nov 17, 2014.
  1. Only John
    Only John New Member
    Nov 17, 2014
    Happy Monday, everyone:
    I have a 2013 JCWMCGP that needs an oil change. I must confess that I do not know where the oil filter is located. On my 2008 MCS with a supercharger it is easily found and I change it all the time.
    Before I start taking off parts, can someone out there point me in the right direction?
    Thank you for the help.
    Only John
  2. DneprDave
    It is under the coolant expansion tank. You can undo the 10 mm bolt that holds the tank on and move it out of the way to access the oil filter, without draining any coolant.
  3. Savvy
    Just youtube "r56 oil change" it'll even bring up a video how to reset the service intervals for the computer. Unless, of course you are still under warranty and you are just doing an extra oil change to play it safe... then don't reset the computer, otherwise the dealer won't give you the freebie oil change.
  4. Metalman
    Hope MINI didn't put one of those "Lifetime" oil filters on it....
    They were getting a little carried away with that sales gimmick IMHO...
  6. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    It takes some looking - unbolt the coolant expansion tank and swing it out of the way, and shine a flashlight under the turbo. You'll see the signature hex head of the oil filter cap.
  7. Minidave
    4,594
    I might also add, the canister is made of plastic with an o-ring seal, don't over tighten it....more than a few have been broken because of overzealous wrench work - the o-ring is what makes the seal, you only want it tight enough to not come loose again.
    And by all means lube up that o-ring. :yesnod:
  9. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    What a great how to! :ihih:
