my pass lock died. I got a new one from eMINIparts.com (excellent price and delivery). While removing the old one I tried to check to see if I had power to the connection and managed to blow the fuse for the locks. I replaced the fuse. Now with the new lock in place the doors will unlock but will not lock except manually. Is there another fuse somewhere? Also my pass window does not go up and down currently. I have tried banging on the door, which worked in the past. Any hints?
It looks like only fuse F37 is associated with the door lock: http://wds.spaghetticoder.org/en/svg/sp/SP0000017983.svg?m=r50 When you say you have to lock it manually, do you mean mechanically? Does the center console toggle switch work? I haven't had any issues with the windows on my MINI, but I've seen lots of people posting about problems. Here's something to get you started: http://www.motoringalliance.com/forums/pittstopmini-club/1053-drivers-window.html
I have to manually lock the doors. push the door button down or use the key in the lock. The central toggle switch will unlock but not lock the doors as well.
:cornut: HMMMMMMMMMMMM.................water/corrosion on electrical terminals somewhere along the line? That does things almost as strange as a battery going out. Jason
Must be your Door Lock Actuator / Locking Check this article it seems like the problem you are having. Replacing the door lock actuator is necessary when the lock stops properly responding to lock and unlock commands from the remote or dash mounted toggle switch. The same procedure is followed for either door; however the driver side actuator does take a bit more time to install as it has the key lock linkage to also get back in place. MINI Cooper - MINI Door Lock Acuator Repair, 2002-2006 Hope this help.
The door lock actuator has been replaced. all fuses appear good. I am concerned it might be the Body Control module.
