MINI Whirring noise
Discussion in 'Starting Line - New Member Introductions' started by pvmanjerry, Sep 28, 2021.
  1. pvmanjerry
    pvmanjerry New Member
    Sep 24, 2021
    Hi
    I am new to this forum and hopefully someone might have some advice.
    My daughters 2011 Mini first 90,000 km is making a strange hard to pinpoint noise that sounds like
    Whirr Whirr Whirr which is mainly noticeable on motorway doing 100 120kiph. as the car slows the noise slows.
    We checked wheel balance on all 4 wheels, have not checked wheel alignment. putting the car in neutral makes no difference, and there is no vibration.. Any ideas?
  2. 00Mini
    Welcome to Motoring Alliance. First thing that comes to mind is a bad wheel bearing or maybe a dragging caliper.
  3. pvmanjerry
    Sep 24, 2021
    I will check wheel bearing but I have had wheel bearings go in other cars and the noise was not like this. I will also check the tracking
  4. MCS02
    Hi Welcome to MA!
    Also take a look at the front half shaft. If one of the boots is torn and lost all the grease it could make this noise.
    Does the sound change when you turn?
  5. pvmanjerry
    Sep 24, 2021
    Hi
    We have checked wheel alignment and wheel bearings as well as visually checking everything underneath.Also done all the usual checks, turning braking etc. All OK but the annoying whirr whirr is still there.
    It is very noticeable on motorway, we can determine where it is coming from ,it sounds like its coming from everywhere.
  6. MCS02
    If you can try driving at a speed where you hear the sound and go around a long turn, both left and right. Does the sound change when this is done?
  7. 00Mini
    Does that check for anything more than front wheel bearings ??
  8. 00Mini
    I had a Saturn Vue that loved to eat front wheel bearings. One time I thought it sounded like wheel bearings were going to be needed so I bought them in advance of actually checking them out. They checked good but since I had them all ready they were put on and as luck would have it that corrected the problem. So it is possible to think a wheel bearing is good only to find out that may not be the case after all.
  9. ScottinBend
    Road noise? Check tire age and condition.
    • Winner Winner x 2
    • Like Like x 1
  10. MCS02
    @ScottinBend is right I don’t know why I didn’t think of that. I have had several tires get old and make road noise.
  11. 00Mini
    Wish the OP would have given us a follow up on what he found and if’n he was able to correct the problem.
  12. dNorman48
    dNorman48 Member
    Jul 24, 2019
    41
    22
    My friend also had similar noise and it goes away after changing tires.
