Engine Drivetrain 2nd Gen S Whistling Metallic Sound
Discussion in 'Tuning and Performance' started by genik, Jun 12, 2016.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    #1 genik, Jun 12, 2016
    Any ideas where this metallic whistling sound is coming from when i hit the gas pedal hard? I believe it is the turbine but id like to hear an opinion. The mini is suffering from a loss of power but at the moment the only codes that i had were P000A-Powertrain and P0420-Powertrain. Any suggestions?
    [ame="https://www.youtube.com/watch?v=jirXP_iQ7us"]VIDEO0025 - YouTube[/ame]
  2. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    That does sound like a failing turbocharger (not turbine, btw). They tend to sound like a dentist's drill when they are failing, and yours sounds like that.
    CD
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    Thanx CD what do you mean "not turbine"? Does that dentists drill as you say could be the shaft touching the mental while spinning? So in other words it should be playing?
  4. MCS02
    What he means is what you call a turbine we call a turbocharger. Good luck I hope it is fixed soon.
  5. oldbrokenwind
    oldbrokenwind Active Member
    Oct 18, 2012
    196
    107
    Northern NV
    You could disconnect the air inlet tube from the turbo, then try to "wiggle" the turbo shaft. There should be absolutely no up / down or side-to-side movement and little-to-none in / out movement. It should also rotate either direction freely. This is not the only way to check a turbo, but it's not difficult either.
    Handle the air inlet hose gently, I've read that this connection can be easily damaged.
  6. genik
    genik Member
    Feb 20, 2012
    402
    19
    Any pic available to indicate the air inlet?
  7. oldbrokenwind
    Oct 18, 2012
    196
    107
    Northern NV
    No, I don't have a pic --- my mods don't include the OEM turbo, and I have after-market hoses through-out the air handling system.
    Follow your hoses from the air filter to the turbo. Disconnect the last hose that attaches to the turbo. If you disconnect the wrong hose, you won't find a shaft to "wiggle". Using your video, it should be the large diameter hose shown at the top, not the one closest to the front of the car, nor the small one going to the coolant tank.
  8. genik
    genik Member
    Feb 20, 2012
    402
    19
    #8 genik, Jun 20, 2016
    So here is my Engine, would it be the hose im indicating with an arrow the one to dismantle in order to look for the turbo shaft wiggling as you say?
    Metal whistle
    Yes that's the one.
  11. Firebro17
    You need to replace that with a hash pipe Genik. Guaranteed that noise will disappear.
  12. Metalman
    Aftermarket or OEM hash pipe?
    Please place a yellow arrow pointing towards said hash pipe...:D
  13. Firebro17
    If he'd ever show his face, I'd place the arrow appropriately.
