Brakes Wheels 2nd Gen Tires Who has fitted 215/45/17 tires?
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Oct 17, 2015.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    I want to fit 215/45/17 tires on my R56S but have no idea how they will look like. Can anyone that has fitted such tires please post pics here so i can make sure of what im gonna be doing. Thanx in advance :Thumbsup:
  2. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    #2 caseydog, Oct 17, 2015
    I am running 215/45/17s on my R56 CooperS on the MINI two piece Web Spoke rims. They look great! They look like they were meant to be there from the factory.
    They perform well, too. No unusual wear at all. I'm on my second set of 215s. The first set wore very evenly.
    CD
  3. versus
    versus Active Member
    Sep 8, 2009
    553
    87
    My Michelin A/S 3's are. ImageUploadedByTapatalk1445110819.298318.jpg
  4. Firebro17
    Buy them Genik. They look good. They don't rub.
  5. AFWingnut
    AFWingnut New Member
    Apr 23, 2013
    41
    22
    Therapist
    Pittsburgh, PA
    Bridgestone RE71Rs
  6. CHKMINI
    I love my RE71R's.
  7. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    Not to be a killjoy, but assuming you are asking about 215/45-17 tires because you are replacing 205/45-17 tires, the difference is negligible. The 215 tires are 10mm wider -- that's just 4/10s of an inch. I think a person is unlikely to be able to spot a difference of less than half an inch of tire width with the naked eye.
    I run 215/45-17 on my MINI simply because there are more tire choices available in that size as opposed to the 205/45-17 size. Pure and simple.
  8. vetsvette
    Probably be a shorter thread if you asked "who hasn't run 215/45-17 on their Mini?"
    That being said, I am very happy with my Goodyears in that size.
  9. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    I personally think there is a very subtle difference in looks, but without looking too wide for the rims. To me, the 215s are a no-brainer.
    But, I totally agree that one tire size shift can make a big difference in the number of tire choices available. I used to own an Audi A6 allroad, and going one size wider, at the least, quadrupled my selection of tires.
    CD
  10. genik
    genik Member
    Feb 20, 2012
    402
    19
    Isn't it true that 215/45/17 tires can and will touch the wheel arches when in pressure? Guys the ones that have fitted 215/45/17 havent you noticed this?
  11. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    That is usually the go to size for most folks with a 17'' wheel...
  12. Firebro17
    See post number 4.
  13. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,699
    924
    physician
    York, Pa
    Yes, it isn't true. They should be fine.
    24.6-24.7" diameter and only 10mm wider - still close enough to stock.
    Maybe some of the more square-shouldered tires in that size on a markedly lowered
    MINI with a full load on board could rub a little, but in general, no.
  14. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Nope. I haven't observed ANY negative consequences at all.
    CD
  15. wmwny
    4,040
    2,242
    I have had no issues with the 205/45/17s on my MCS other than a hard, feel-every-bump ride. The wheels are from my wife's S and I switched out my 16" set with her 17s this Spring so she could get a softer ride.
  16. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    So generous of you :biggrin5:
  17. BlimeyCabrio
    Yep. 16" is the best overall street wheel size for MINIs, IMO. But of course people will continue to buy 17" and 18"...
    Disclosure statement: I currently own 15", 16", 17" and 18" wheels for my MINI.
  18. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    The issue with 16's is the lack of tire selection sizes.
  19. AAONMS
    AAONMS Well-Known Member
    5,027
    221
    I play with trains...
    Fruit Cove, FL
    Mine don't. Even Dragon runs don't create an issue.
  20. BlimeyCabrio
    Star Specs are available. Nothing else matters. :devil:
