1st Gen R50 Cooper Wide Band 02 sensor
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by RallyMini370, Sep 11, 2014.
  1. RallyMini370
    I bought the autometer wide band gauge and 02 sensor but didn't realize this is a standalone set up. Meaning I have to drill another hole for the wideband 02 sensor. Is it possible to use the wideband 02 sensor with some splicing of wires in the place of the OEM 02 sensor?
  2. RallyMini370
    looks like not!
  3. DneprDave
    Have an exhaust shop weld an O2 bung in your exhaust pipe.
  4. nkfry
    nkfry New Member
    Roseville, MI
    There is a science to wideband install, it has to be far enough from the collector so as to not prematurely burn out, as well as being evenly placed between the 4 ports so as to get an accurate reading of all the cylinders collectively.
    You can't wire into the factory harness, and you will have to have a bung welded in, the problem with the stock header is there is limited space to do so properly.
    Why do you feel the need for the wideband? Are you planning to uprate injectors, cam, head, and tuning?
    If not, there is no real need for a wideband on a stock car with an exhaust and intake.
  5. Dave.0
    #5 Dave.0, Sep 12, 2014
    His car is a real Race / Rally car not a Daily Driver.
    http://www.minispace.com/en_us/article/DIY-MINI-Race-Car-Wins-Big-Watch-An-Amateur-Racer-Steal-The-Show/988/?eid=988&utm_source=FacebookMINI&utm_medium=rich_link
    http://www.motoringalliance.com/forums/project-car-builds/12731-rally-mini-cooper.html#axzz3D7HGUYuW
    [ame="http://www.youtube.com/watch?v=hWauCoHT1yQ"]http://www.youtube.com/watch?v=hWauCoHT1yQ[/ame]
  6. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    Race Car? i see a spare tire in there. :ihih::lol::cornut: ;)
  7. RallyMini370
    thanks Chaps I just wanted another gauge to monitor the engine. I went up to the muffler shop and got an extra 02 bung welded in. The gauge works fine now and shows the engine is running slightly lean . 14.8 to 15.2 at idle and part throttle and around 13.2 when at WOT.
  8. nkfry
    nkfry New Member
    Roseville, MI
    Those numbers aren't that bad actually, 12.5 is where you're going to see the best torque #'s out of a naturally aspirated engine, so you're within half a fuel point.
    You'll almost always fight to keep the car in stoich, due to constant barometric changes, temperature changes, humidity, elevation, etc. Most tuners, as well as enthusiasts with the need/want to stay stoich, or in the powerband will have numerous tunes for different times of year, weather, elevation, and all that jazz.
    That said, more gauges are never a bad thing! :cornut::Thumbsup:
  9. RallyMini370
    Thanks for the input. Question: Is the temperature sensor on the front bumper used only for the A/C or is the EMC using it too? Seeing as mine is bolted to the gearbox to monitor the temperature there.
