Will it work? Place your bets!
Discussion in 'MINI' started by caseydog, Dec 9, 2015.
  1. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    Spin cycle. :eek:
    I'm going to let it dry overnight, and give it a try. Make your predictions!
    CD
    I say Will Not Work
  3. 00Mini
    2,227
    This the Christmas Season so miracles can happen, therefore I'll cast a yes vote !! If'n it doesn't it's not to late for Santa to bring you a new one.
  4. papa-j
    papa-j Active Member
    378
    112
    Minneapolis, MN
    My guess is it won't work without an intervention.... :fingerscrossed: You can try to dry it out - many posts on the web for this issue (like this one)
  5. MCS02
    it will work
  6. whaap
    whaap New Member
    Jan 10, 2014
    515
    313
    Tucson, Arizona
    My vote is yes.
  7. ScottinBend
    Just make sure to rinse well and put it in a bag of instant rice to dry out.
  8. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    It is VERY well rinsed. :frown2:
    But, I completely forgot about the rice hack. Thanks!
    CD
  9. rkw
    rkw Well-Known Member
    443
    I suspect the key will work fine even without special treatment. This is not fragile electronics that operates within close tolerances.
    Not necessarily, since it had gone through a wash cycle that may have left chemical residues. The ideal treatment is to completely flush it out with distilled water.
    As for using rice, it is an urban myth and not effective. Rice absorbs liquid when immersed in boiling water, but it is not good at pulling moisture from the air.
    http://www.cnet.com/how-to/using-desiccants-to-soak-up-wet-electronics/
  10. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Well, that was a bit of a roller coaster ride. First you tell me it should be fine, and then you tell me I'm doing it wrong. :confused5:
    Oh, well. At least I have a second working key fob. I just need to remember to check my pockets before I wash my pants.
    CD
  11. Metalman
    Pop the battery lid off and remove the battery. Water has shorted it out so if it's not dead, it's been weakened. With the battery out the moisture will be easier to escape... The battery cover does have an "O" ring, so it may or maynot be dry inside.
    I say yes, if it's dried sufficiently...
  12. mrntd
    Rice may not work as well as a descant bag. But it still does do something.
    I'm with MM on opening it up to make sure it drys out completely.
    Thanks for the article rkw now I know what to look for when buying a used phone.
  13. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    Is that an optical illusion? It looks like the key part of the fob has melted into the barrel of your dryer. My vote is dependent upon whether it has melted.
    Melted: no worky
    Unmelted: worky
  14. MCS02
    The game is does it work or not! Its not does it work under conditions!
    Your cheating!:biggrin5::lol:
  15. Zapski
    Open, remove the battery, clean with 99% Isopropyl Alcohol and a soft toothbrush.
    Might have to go the to a pharmacy for the 99%. 91% won't work as well.
    This is how I clean liquid spills from computers and restore them to functionality. I'm typing to you on one of those right now. It's not 100% guaranteed, but we have a pretty good success rate. It depends on how long the liquid has sat unattended.
    That said, I've also seen things like iPods go through the wash and come out OK. Your milage may vary.
  16. DneprDave
    My cell phone went through the wash and survived, your key should be alright.
    I poured 99% isopropyl alcohol through my phone, it mixes with the remaining water and evaporates fast. (I took the battery out while rinsing it in alcohol.)
  17. ScottinBend
    INSTANT rice......not regular rice.
  18. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    It never made it to the dryer. In the picture, it is resting on the rubber gasket thingy of the washer, with the clothes doing about 1,500 RPM in the background.
    CD
  19. caseydog
    Nov 7, 2012
    2,433
    879
    Dallas
    Okay... drum roll please...
    IT WORKS!!!!!
    It unlocks the doors. It locks the doors. It opens the hatchback. It fricking starts the car! Woohoo! That is one tough key fob. :Thumbsup:
    CD
    My guess is it will work. :D
