Engine Drivetrain 1st Gen Cooper Will this transmission fit my Mini?
Discussion in 'Tuning and Performance' started by flashover604, Jun 29, 2015.
  1. flashover604
    flashover604 New Member
    Mar 11, 2015
    33
    Phone man
    Lancaster, Ohio
    Hi all. I wanted to check here and see if a 5 speed transmission out of a 2006 Mini Cooper base model will interchange with a 2003 base model Midlands. I have a 2003 with a whiny 5 speed and have a chance to buy a 5 speed out of a wrecked 2006 base model.
    Thanks in advance!
    Zach
    If I remember correctly it is a straight swap.
  3. ZippyNH
    The CV joints have a different number of splines....
    So more than just a swap...you need matching CV joints.
  4. ScottinBend
    I thought the 2006 went to a 6 speed or was it a Getrag instead of a midlands.......:confused:
  5. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    There is an interesting "How to" in the Gen 1 section of the library. It will give you an idea of the kind of work involved in the conversion that you are thinking of doing. :Thumbsup:
  6. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,651
    912
    physician
    York, Pa
    Need a bunch of new parts if going from a Midlands to a 5-speed Getrag or a 6-speed Getrag.
    Count on new axles, flywheel, clutch, clutch lines, starter, mount, and maybe shifter box and cables
    (depending on the exact box and cables you have now). These parts add up to about as much as the
    transmission itself.
    It's a little cheaper than going to the 6-speed Getrag, but not by much, mostly the difference
    in the cost of the transmissions themself.
  7. RallyMini370
    Not a straight swap, 2006 5 speed is from the Ford KA and needs all the parts above, plus it is not much better than the Midlands. If you use the Mini for regular street use I'd go fix the Midlands. If the box is shifting ok then the input shaft bearing will be on its way out. Just pull the box, get some new bearings and you should be good for another 70,000+ miles.
  8. 00Mini
    2,227
    This is good advice from a person who can probably take apart and put together a Midlands 5 speed blind folded.
  9. RallyMini370
    Thanks 00Mini I dream the Midlands! LOL Or flashover604 can go fit a straight cut gear set for a real whiny sound. hahaha
  10. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    The incorrect-for-that-model trans swap is something we've never done--thankfully. I know other vendor have done it with good results. When I get inquiries about it, I try to steer the owner away from the idea. Ultimately, you're better off selling your car and getting another one with a better trans/motor package, like sell your R50 for a R53.
  11. RallyMini370
    True Eric but to help the lad out. Fixing the Midlands is easier. I bet his Mini has done 70,000+ miles so fixed correctly it should last the miles again.....plus who's going to buy an R50 with a dodgy Midlands box? Only me! hahaha
  12. flashover604
    Mar 11, 2015
    33
    Phone man
    Lancaster, Ohio
    RallyMini, I've got a mini for sale. 89,000 miles....lol!
  13. RallyMini370
    Thanks....just need the gearbox!
  14. RallyMini370
    but really, don't sell it because the gearbox is talking. Go get it fixed. Damn I should travel the US fixing the Midlands. Strange because I'm from the Midlands in the UK...LOL
