Window stuck
Discussion in 'Mid-Ohio Motoring' started by IMGRFX, Jul 27, 2012.
  1. IMGRFX
    IMGRFX Club Coordinator
    Oct 18, 2010
    731
    241
    Driver's window. No moving. It's up! Help me.
  2. miniconcarne
    miniconcarne New Member
    38
    Machinist
    Home
    Give nice smack under the tweeter speaker, ala Fonzie.
    When do you say "Ayyyyyyy"?
  4. CHKMINI
    I'd forgotten about that fix....when I owned my '04 the same issue occurred, I did the smack under the speaker and the window was back to normal. Thanks for the memory. Carol, if you need someone to beat on your car, just let me know.
    Carol they speaketh the truth. A tech from Classic MINI told me that old school fix years ago. Thankfully I have not had to implement that technique. Maybe at the next get together we can all have a whack at the door. :smilewinkgrin:
  6. Metalman
    That's nice Chuck....
    But let's use mine, I have a full set of metric hammers......:D
  7. Dave.0
    Metric Hammers:lol::lol
    I have a rare set of special edition Torx Hammers.:Thumbsup:
  8. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    If hitting the door does not work.
    I once had a problem with the switch not making good contact. I had to push in on the toggle switch then move it up/down to get the window to work.
  9. CHKMINI
    Carol, open the door, get your hand in a fist, get ready to swing, yell "SEWING SITE" as loud as you can and then make contact.....window should now work!
  10. IMGRFX
    Oct 18, 2010
    731
    241
    I yelled SILVERBACK SALUTE.. Then ouch... But it's working again. Thanks guys.
  11. miniconcarne
    38
    Machinist
    Home
    :Thumbsup: My 03 does this when it's very hot outside. So far the smack technique has worked everytime.
  12. lotsie
    stagehand/part time detailer
    Right here
    That fix has worked for years on my 03:Thumbsup:
    Nice to know that technique is a long term fix. :Thumbsup:
  14. lotsie
    Right here
    Poco has had the issue going on 10 years:fingerscrossed:
  15. DwightB
    DwightB New Member
    Oct 6, 2011
    9
    Westerville
    Does this fix work for all auto repair issues? Just hit it with a hammer? :)
  16. goaljnky
    3,105
    394
    I don't see why it wouldn't. Certainly does wonders for marriage problems. :devil:
  17. drabdub
    drabdub Well-Known Member
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    bump for an old thread but mine isnt working after i hit it and the window clicks when i hit the dash switch.
  18. IMGRFX
    Oct 18, 2010
    731
    241
    Just keep trying. Hit the door then toggle the switch. Has happened twice now and I get it going again.
  19. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Most likely there is poor contact between the window motor brushes and the copper bars on the commutator. Although cleaning the bars is easy, accessing the window motor is a pain in the neck. I can reach the window motor through the door speaker port to pull the magnet housing and armature, without disassembling the door internals as was done in the first section of this reconditioning guide.
    I use 2000 grit wet/dry paper, and apply light pressure. The copper coating on the bars is thin, don't rub aggressively. Only the gates behind the brushes need to be pulled to release pressure on the springs.
  20. drabdub
    Oct 22, 2009
    1,035
    Logistics Lead
    San Jose, CA
    i got it to work...just needed a bigger hammer and to hit the switch at the same time
