1st Gen R52 Cooper Convertible Windscreen....what kind?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jiminni, Mar 31, 2013.
  1. jiminni
    jiminni Well-Known Member
    262
    Ca.
    So...what windscreen do you guys and gals recommend for the 1st gen convertible? Brownflyer, Windblox, OEM......? Any help is appriciated :biggrin5:
    If you can, try and get Pilkington glass.
    Automotive
  3. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    I had a Pilkington put it on my R50 and it was great. Not a problem.
    Pilkington here too. Justa as important, make sure the installer knows what they are doing.
    The OP is not asking about windshield glass but a wind blocker that goes behind the front seats.
    MINI Part # 54-34-0-390-513
    Oh man I done it again. :crazy:
  7. jiminni
    262
    Ca.
    Thanks Nathan, kinda was confused for sec :lol: Yes, wind blocker for rear seat area. OEM seems excessively priced :eek6: Hoping for something more reasonable.
    At least when you need a front screen we've got you covered. :eek:
  9. Tron Chief
    Tron Chief "Need More Coffee"
    60
    Maintenance Supervisor Del Monte, retired 30 year
    Lemoore California
    I typically drive top down with the windows down regardless of the weather as long as I'm at speed before the rain starts I keep on going. I have seen temps of 25-120F all of which has been windows down, top down. When I was a passenger in my wife's Cabrio we had the Brownflyer windscreen. The ball of cold air that comes between the two seats and goes all the way up to the gearshift knob was removed from the middle of the car and a notable blast was added to the outside of the seats by the doors. With this in mind when I got my Cabrio I started looking at other options since I had paid the extra money for a convertible I wanted to use it as much as possible. While the Brownflyer does allow for full use of the back seat I wanted to see how it compared with the OEM model and was first able to get a 2nd generation OEM windscreen. It fits and functions well however I did notice when driving in the 20 degree area the "V" in the middle that is designed to go around the 2nd Gen's seat allowed a little of the ball of cold air to go in between the seats however it only went about 8-10 inches onto the front area however the buffeting of the wind was gone when driving at highway speeds with the windows down and removed almost completely if you drive with the windows up. Seat warmers and heater with the windows down cured the problem and I placed a small black towel into the V to closed the gap. I was curious on if this ball of air was present on the 1st generation and finally found one available for less than the $250 you typically see them starting at. Minimal air ball on both the sides and middle with the 1st generation OEM wind screen only getting about 3 inches in between the front seats and the same results with regards to the wind buffeting. Unlike the full use of the backseat available with the Brownflyer I find myself throwing my bump cap, jackets, golf clubs etc. below the windscreen in the back seat as it keeps them safe and out of sight when the top is up and the car is parked. Our Brownflyer is in my wife's Cabrio however she is a Sun's up Top's down kind of Gal and in my opinion misses out on many opportunities by limiting her time. Just a side note rain will go over your head at speed however it will drop from the top corners of the windshield onto your knee and onto the door panel, however the looks on the other drivers as you go whipping by them is a classic. I have a second generation OEM windscreen available if your interested.
  10. Razone23
    Razone23 Active Member
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    Just curious if you still have windscreen up for grabs and will it fit my R52 ?
  11. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    I sold a 2nd gen windscreen to a friend with a 1st gen cabrio and it worked just fine so it should fit.
  12. jiminni
    262
    Ca.
    I bought his Gen 2 windscreen. Yes they fit and work very well.
  13. Razone23
    Nov 3, 2013
    175
    27
    technical support
    nothern CT
    Thanks guys. Ordering this week as the weather will improve soon, in CT
