Windshield Dilemma
Discussion in 'Detailing' started by JECO, Dec 7, 2015.
  1. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Newsletter producer, retired DOT chief
    Crozet, VA
    Disgusted over the grime I was unable to remove from the windshields on my Roadster and wife's Countryman, I decided to search MA for a solution. When I read about using 000 or 0000 steel wool, I thought I would try it. Wow, it works. And wouldn't you know, the advice came from our lost guru, Dave.O!
    Gone but not forgotten
    He is was quite the detailing guru. I use his secret sauce on the plastic trim on Skooby.
  4. MCS02
    That worked wonders.
    Dave's secret sauce the best there is. :Thumbsup:
  6. Zapski
  7. ScottinBend
    Still like my 303 Protectant.......no runner gloves or mask needed.
    :biggrin5:
  9. Zapski
    Good to know. I may give it a try this spring. Figure if it doesn't work I can buy a new one. ;)
    You have more energy that I. Let us know how it works out.
  11. caseydog
    caseydog Well-Known Member
    Nov 7, 2012
    2,433
    879
    Automotive Photographer
    Dallas
    You get worn out by a Google search. :frown2:
    CD :biggrin5:
    On my MINI I used Prima Nero, great stuff. On Skooby it had never had the plastic treated. Dave O's secret sauce brought the trim back.
    What's a runner glove Scott & what's with the mask?
  13. ScottinBend
    .......rubber gloves :p
    and the mask for the fumes. At least that's what the warnings on the product said.
    Oh heck what's a few brain cells? Never hurt me none...... :crazy:
  15. DneprDave
    Rubber gloves and a face mask!?
    Jeeze, what are you putting on your MINI!
  16. ScottinBend
    Dave.0 had some really nasty stuff he would suggest to treat the black plastic trim. Forgot the name of it.
  17. Crashton
    Secret sauce. Great stuff.
  18. vetsvette
    Penetrol.
  19. mrntd
    It's in the house paint area of the hardware store. It is uses to give house paint a smoother finish. It works well and lasts for a couple of years. Getting remainders off to retreat it can be a pain.
  20. vetsvette
    Directions for applying Penetrol. (from Dave.0)
    applying Penetrol…..
    One can will last years and you will be able to do 10 or 20 cars easy. You don't have to mix it with anything just apply it right from the can with a sponge that you will not use again. Trash the sponge when you are done because when it dries it will be hard as a rock and will not wash out. (Oil Based)
    For prepping your trim just clean your trim with lacquer thinner or acetone to remove any old silicone based dressings. Next wipe on a nice coat of Penetrol but don't let it run. You will see what I am talking about when you apply it.
    Let it dry overnight and add another layer the next day. Your trim will look better than brand new for a year and it will resist dust and stuff and it will not wash or wear off.
    * If you get sloppy when applying it and get a little on your paint wipe it off ASAP before it dries or you will have to use lacquer thinner or acetone to remove it from your paint. It's not real big deal but you will need to re-wax that painted area since the lacquer thinner or acetone will strip off the wax.
    If you ever need to remove it use lacquer thinner or acetone and wipe slowly and it will come off.
    I have also taped up my bumper and sprayed it on all 3 of my front grills with an old Windex bottle and wiped a layer on my wiper arms. This stuff is awesome.
    Let me know how it looks when you are done..
    Dave
