2nd Gen R59 Roadster Windshield Moulding
Discussion in '2nd Generation: 2007+ R55 through R61' started by JECO, May 28, 2012.
  1. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Newsletter producer, retired DOT chief
    Crozet, VA
    Hate to admit it, but where the moulding overlaps at the base of the windshield the moulding is pulling away and leaving a gap. I plan to bring it to the attention of my dealer, but wondering whether other Roadster owners have had the same issue.
  2. minirab
    Had the same thing happen on my R58, they fixed it in ten minutes. It
    remains to be seen if they will have to do it again.
    Can you lease post a picture of this issue.
  4. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Crozet, VA
    Nathan and all, here is a photo of the detaching moulding.
    Thanks, now we know what to look for.
  6. Metalman
    Not a big problem....
    I completely removed mine when I was messing around installing my IE fixed camber plates. It had nothing to do with the IE install, I just wanted to see what was under there.
    There is a clip that attaches to the bottom edge of the windshield glass. It acts as a receiver for the loose piece noted in your picture. You or the dealer may need to reattach this receiver clip which will then hold the loose piece in place.
    It's attached to the bottom edge of the glass. Behind the battery along the top edge of the firewall very top edge of the picture. It's a black plastic receiver clip. Your loose trim snaps into it and is held tight to the glass.
  7. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Crozet, VA
    Thanks Metalman. I will take a look to see if I can perform that operation. Otherwise I will take it to the dealer. I appreciate knowing it is not a big problem.
  8. JECO
    JECO Active Member
    Apr 22, 2012
    228
    98
    Crozet, VA
    The receiver clip was in place. I merely snapped the trim into it. Thanks again Metalman. Help like this is another reason for supporting MA!
  9. old81
    1,542
    After 5 years and 2 windshield installs and a new battery install, multiple folks not me working on my 07 MINI, my cowl trim was similar to this issue, but bent/warped.
    I had the dealer replace it, nice to see fresh cowl pieces each day, not gap, no warpage. :)
  10. Desy232
    Desy232 Banned
    Dec 4, 2017
    10
    I'm new to this issue and you helped me.
