Wiper delete solution
Discussion in 'MINI' started by Nitrominis, Jul 3, 2010.
  1. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    And for the majority of us not in the UK Craven Speed has a similar item available direct or from your favorite Craven Speed retailer. Rear Wiper Delete
  3. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    Nathan on top of it! :Thumbsup:
  4. Qik
    Qik Well-Known Member
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    #4 Qik, Feb 23, 2018
    Just deleted my rear wiper and didn't notice a thread on how-to here.
    Here's some pointers to anyone that wants to do this-
    Remove this 13mm nut-
    Once the nut is all the way lose, give it a turn so it catches some threads, leave the socket on and press the blade off with something like this. Don't bother trying to pry it off.
    Onto the inside, remove the 2 star bolts that were here (removed before pic)-
    IMG_0881.JPG It's hard to see, but there's 8 circled spots where the clips are located. Pop the bottom of the panel off attacking the middle 2 first with a long trim panel tool, then do the 2 outers. Once all 4 bottoms are popped, stick your arm up in there and get the middle first here too. Pop them out with your hands, doesn't take too much pressure, then use your hand to pop the outer 2 after.
    IMG_0886.JPG Pop off the elec. connection and remove those 3 10mm bolts. Pull rubber hose off before or after, I did it after. Pull off motor, remove the rubber grommet and store all your now un-used wiper assembly-
    Plug hose. I used a GM plug from Auto Zone, part number was 458140, Trim Panel Retainer is what it was called on the package- I heated the hose a little to soften it up to jam the plug in-
    Plug the window hole with a 1" plug of your choosing, I used this one- http://www.urotuning.com/Rear-Wiper-Delete-Plug-Mk4-Mk5-Mk6-Mk7-Golf-GTi-a-p/uro-wiper-delete.htm -
  5. MCS02
    Good job! This would make a great how to.
    • Like Like x 1
    • Agree Agree x 1
  6. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Agreed - on the how to and good article. Let’s convert it. :)
  7. Qik
    Oct 27, 2015
    1,421
    670
    IT
    Atlanta-ish
    Please do!
  8. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    Will do - on the road this week.. working from phone. Will convert this weekend. :)
