Exterior 1st Gen Wipers
Discussion in 'Tuning and Performance' started by Kenny kustom, Mar 26, 2015.
  1. Kenny kustom
    Kenny kustom New Member
    Jan 24, 2015
    297
    178
    I'm finding, the passenger wiper doesn't contact the windshield all the way. Through the whole stroke. Seems the curve of the windshield is too much for it??
  2. Savvy
    Put an 18" blade on that side.
  3. Kenny kustom
    Jan 24, 2015
    297
    178
    It's an 18" drivers is 19".
  4. ZippyNH
    if you can still find PIAA silicone "curved" wiper blades/frames (uses regular piaa silicone refills) they work great, and have great coverage....
    i have seen the curved in the clearance areas...so they might be getting discontinued as more wipers are made as "mono-blades"....absolute crap imo....but a great way to sell a more $$ product....
  5. Kenny kustom
    Jan 24, 2015
    297
    178
    I might try a 20 or 21 on the right.
  6. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,651
    912
    physician
    York, Pa
    #6 cristo, Mar 26, 2015
    Yep, I use a curved PIAA 18" on the right.
    Here it is:
    http://www.amazon.com/93245-Super-Silicone-Curved-Black/dp/B00067BXVM/ref=sr_1_1?ie=UTF8&qid=1427422242&sr=8-1&keywords=18+curved+piaa+silicone
    Here's the refills - price is higher here than they used to be - so maybe look elsewhere.
    Also - look at the suggested price typo $1504?????
    http://www.amazon.com/94045-Silicone-Wiper-Blade-Refill/dp/B0002Z9R0W/ref=sr_1_1?ie=UTF8&qid=1427463921&sr=8-1&keywords=18+piaa+silicone+refills
  7. Kenny kustom
    Jan 24, 2015
    297
    178
    #7 Kenny kustom, Mar 26, 2015
    I'll try them out!
  8. DryMartini
    DryMartini New Member
    Dec 6, 2012
    1,048
    479
    Ours would start skipping, sticking, leaving black marks and not working worth a carp. Changing blades would only work for a while, then it would start again. Finally could reproduce the problem at the dealer and they adjusted the arm on the spindles and that has cleared up the problem.
    Perhaps you might look at that too and make sure they've got the right amount of pressure on the arms.
  9. Kenny kustom
    Jan 24, 2015
    297
    178
    There's good pressure, and where the wipers touch, they clear very well. They are Bosch icons.
    It's just not physically possible with the curve of the windshield, to contact the whole area.
    Without using a curved blade.
  10. Nathan
    I've tried those Bosch blades in the past. Now I go with the OEM ones.
  11. Savvy
    I just bought a set of PIAA AeroVOGUE blades a couple weeks back. Zero complaints. Got the 18" for the driver's side, 19" for the passenger. there is a little bit of lost contact on the passenger side in the last 2 to 3 inches of travel.... but the blades don't flutter and it doesn't bother me enough to swap the blades.
  12. Kenny kustom
    Jan 24, 2015
    297
    178
    I have always used the Bosch ones.
    Although, never had so much curves....
  13. Savvy
    Once you switch to silicone blades, you'll never look back... while wondering why they aren't standard on all cars.
  14. Kenny kustom
    Jan 24, 2015
    297
    178
    I ordered a pair of 20" curved.
