Engine Drivetrain 1st Gen Cooper WMW CAI
Discussion in 'Tuning and Performance' started by impulse, May 8, 2015.
  1. impulse
    impulse New Member
    May 6, 2015
    Retired Aeronautical Engineer
    Central Florida
    I guess this is the correct forum to post my questions about modding my 2005 Cooper for STF autocross. I have been considering adding a CAI and wondered if any one here has any first hand knowledge about the WMW version. Also wondered how it compares to the aFe CAI also carried by Way. The picture on the WMW website doesn't really show the parts involved. Also the dyno results showing a comparison to something (I assume to be a stock filter) makes me wonder how it compares to the drop in K&N that I already have. Is the ~$200 investment worth it? Would appreciate your comments.
    I'm a fan of the Craven Speed CAI. Well build and solid. Easy to clean.
    Yep, correct forum too. Thanks. We'd of moved the thread and informed you if need be though.
    #3 Steve, May 8, 2015
    Does Craven sell a CAI for the Cooper? I don't see one. (impulse has an '05 R50)
    I like my AFE (have an '02 R50). Fits well, easily installed and sounds great but I can't say anything about actual performance effects. I suspect it represents little improvement in that regard. On the other hand, I haven't bought a new air filter in years. But that aspect won't be an improvement over your drop-in since, I assume, that K&N filter can be cleaned and reused.
    If you buy something, make sure you check carefully that it will fit your MINI's model year. The first generation Cooper (R50) was produced through '06 but I'm pretty sure the first gen air box changed shape along with the other changes that came with the '04 "face lift" so aftermarket replacements might also have had to change. Point is, "fits R50" doesn't necessarily work for every part.
  4. Dave.0
    DDM intake Done :Thumbsup:
  5. mattc85
    mattc85 Active Member
    Sep 24, 2013
    277
    222
    Heating and Air
    Mocksville, North Carolina
    I cut the bottom out of my stock airbox. I used my dremel and cut around the structural ribs. It sounds better and didn't cost me $200.
  6. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    The C stands for "cold".
  7. wmwny
    4,040
    2,242
    Alta covered airbox with a silicone tube. I like it and it has never given me any problems.
  8. CHKMINI
    I been told by many that the JCW air box is the best....FWIW.
  9. Nathan
  10. CHKMINI
    My bad....I was thinking R53.
    I was too when I mentioned the Crave Speed one.
    However, an R50 JCW tuning kit, now that would be like finding hen's teeth in a Unicorn's poop.
  12. mattc85
    Sep 24, 2013
    277
    222
    Heating and Air
    Most aftermarket "cold" air intakes are just open element filters that breathe ambient air from the engine bay. Without a tune and probably other changes, the only benefit one will see from an aftermarket intake on a naturally aspirated R50 will be a little more sound.
  13. Dave.0
    Real cold air intakes for a MINI are sealed box in the engine compartment and ONLY pull air from the cowl vent on the driver side.
    All the other ones are just noisemakers.
    That's not exactly the Justa configuration. The idea is right but the location of air source is different. :)
  15. Dave.0
    Oh we are dealing with a Justa. .... It JUSTA does not matter. :lol:
  16. mattc85
    Sep 24, 2013
    277
    222
    Heating and Air
    That is precisely the reason for my suggestion. Couldn't have said it better myself. But there is the placebo effect....
  17. aslondon
    aslondon Member
    41
    19
    Retired School District Director of Operations
    Monticello, FL
    I did the DDM on my R50 along with some chip tuning and below 4 grand there is not much more than a throaty sound. However, above 4 grand the motor seems to come alive. Pretty narrow power band 4-6k within which to "come alive" but I would do it again. The DDM does seal the box and the cool air from behind the grill is routed into the box. Not a bad setup.
    Al
